High Temps
shardbearer
I have a Toshiba Sattelite laptop with an AMD Turion mobile. Idling with no programs, clean restart, I get 50-60C, and after a few minutes of browsing the web it is 85-100C. Currently with 7 tabs open and one other really light program, I am at 91C. When I do light gaming (Minecraft) it stays in the 95-105C range. These are at the CPU, checked with Speedfan. Is this OK?
    Toshiba Sattelite
    AMD Turion x64 x2 Mobile TL-64
    TOSHIBA IALAA (Socket M2/S1G1)
    2.0GB Dual-Channel DDR2 @ 313MHz (5-5-5-15)
    ATI Radeon X1200 Series (Toshiba)
    Realtek HD Audio
    generic 1280x800
Lol. The people in the other thread were freaking over 80C.
Anyway, this is a Satellite A215.
Found this which says that for a similar model the max is 95C.
    Toshiba Sattelite
    Realtek HD Audio
    generic 1280x800
This is a A215-S4767 by the way.
EDIT: This one posted and the other didn't? The other said the mods needed to check it and I thought it was standard for new users. Huh.
    Toshiba Sattelite
    Realtek HD Audio
    generic 1280x800
I did not find the specific temperature guidelines, but your nubmers are high.
No, amd is 70's you're way too high.
Try coretemp. BUT YOU NEED TO CLEAN OUT THE AIR DUCTS!
Btw I'm freakin out at that temp! unless they really are F.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
