Power Supply good or bad?
im running a 850W power supply with a AD x6 core, and 2x MSI 5830 twin frozers, 2 hard drives and 2 200mm fans, and 4 120mm fans, is this enough power? i notice in AMD overdrive my second card just stays at 300mhz and it should be at 800mhz
    Custom built Desktop
    AMD Phenom II X6 1090T Black Edition 3.2Ghz
    MSI 890FXA-GD70 AM3 AMD 890FX
    8GB Adata Gaming series 2.0 DDR3 1600
    MSI Twin Frozr 5830 X2 with MSI 5850 Crossfired
    Asus 19", Acer 17"
    1400x900
    OCZ Agility 3 60gb, 500GB F3 Samsung Spin point and 5 other HDD's
    850W OCZ
    NZXT Phantom
    2 200mm fans with 6 120mm fans
    Saitek 2
    Logitec G9
    Major AMD, ATI and MSI Enthusiast.
i tried that, its just im worried tat my PSU is failing or isn reaching capasity
    Asus 19", Acer 17"
    1400x900
    850W OCZ
    NZXT Phantom
    Saitek 2
    Logitec G9
Whats the requirements for ATI crossfire x3? will a 850w take it?
    Asus 19", Acer 17"
    1400x900
    850W OCZ
    NZXT Phantom
    Saitek 2
    Logitec G9
I hAd my sli gtx260s overclocked, q6600 overclocked in a antec 900 case.
My APC UPS reported 520W running everything 100% load.
The ati cards and x6 are less power hungery than my setup.... You'll max out bout 500W i bet.
What psu is it? A lesser quality won't put out 850, but more like 780-800W.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
its a OCZ GameXstream OCZ850GXSSLI
OZC 850W powersupply
    Asus 19", Acer 17"
    1400x900
    850W OCZ
    NZXT Phantom
    Saitek 2
    Logitec G9
Youre all good.
While OCZ aren't my top ranked psu, its far from being crap.
It'll be okay... Whats telling you your gpu is stuck in 2d mode?
