laptop cooling pad
mrclub
Banned
i wonder how should i choose a laptop cooling pad
should i choose 1 with only 1 fan, 2 fans or 3 fans ?
also, should i choose 1 that is made of plastic, metal or aluminum.
hmm...
    Acer Aspire 4937G
    nViDia GeForce G105M
Welcome
The more fans the more protection you desire at additional cost.
Why not download speed fan and see how high the temperature actually gets and then you can decide how much protection is desired.
http://www.almico.com/speedfan.php
About Laptop Cooling Pads | eHow.com
Again with the matrial that is used to manufacture the pad, the more expensive gives the most protection
http://ezinearticles.com/?How-To-Choose-A-Laptop-Cooling-Pad---Laptop-Design-and-Build&id=5176631
When you test with speed fan if you are only marginally overheating or not at all go for the cheaper types. If you overheat excessively then the more expensive pads are desirable.
Actually I got one that is a cheap 30 dolloar one from Target..It was a gift from my sister in law..and I got a USB LED desklamp that has a fan on it..It is cooling my laptop nicely...The lamp was from ebay 8.99 buy it now free shipping, I recomend it nicely
    Acer Aspire 5315
    2 gb
    C drive
    D Drive
    Standard Acer Aspire Case
    Cooling Pad and USB Desklamp/fan combo
    DSL 20mb/s
    I run a 60watt speakers from my headphone jack, and I got 10port USB HUB USB Wireless adapter foer the internet
Thats great... I seen on ebay, a laptop table with a cooling pad that adjusts angles and has a camera for like I think 25bucks Buy it now free shipping.. I couldnt use it because I have a a keyboard and mouse for mine and there is no room on the table... I saw Some realy good USB Speakers for under 10 bucks today....
    Acer Aspire 5315
    2 gb
    C drive
    D Drive
    DSL 20mb/s
