laptop cooling pad
  1. #1
    Banned
    XP/Vista Home Premium
    Local Time: 06:25 PM
    laptop cooling pad
    i wonder how should i choose a laptop cooling pad
    should i choose 1 with only 1 fan, 2 fans or 3 fans ?
    also, should i choose 1 that is made of plastic, metal or aluminum.
    hmm...
  2.
  3. #2
    richc46's Avatar
    BSOD Squad
    Fairfield County, CT
    Windows 7 SP1 x64
    Local Time: 06:25 AM
    usa us connecticut
    Re: laptop cooling pad
    Welcome
    The more fans the more protection you desire at additional cost.
    Why not download speed fan and see how high the temperature actually gets and then you can decide how much protection is desired.
    http://www.almico.com/speedfan.php
    About Laptop Cooling Pads | eHow.com
    Again with the matrial that is used to manufacture the pad, the more expensive gives the most protection
    http://ezinearticles.com/?How-To-Cho...ild&id=5176631
    When you test with speed fan if you are only marginally overheating or not at all go for the cheaper types. If you overheat excessively then the more expensive pads are desirable.
  4. #3
    TomSawyer1977's Avatar
    Senior Member
    Mesa Arizona
    vista home basic
    Local Time: 03:25 AM
    usa us arizona
    Actually I got one that is a cheap 30 dolloar one from Target..It was a gift from my sister in law..and I got a USB LED desklamp that has a fan on it..It is cooling my laptop nicely...The lamp was from ebay 8.99 buy it now free shipping, I recomend it nicely
  5. #4
    rjkmetalman's Avatar
    Newbie
    Anaheim
    Vista Home Premium 32bit
    usa us california
    i just got a $20 dual fan from staples and it works great!
  6. #5
    Senior Member
    Mesa Arizona
    vista home basic
    usa us arizona
    Thats great... I seen on ebay, a laptop table with a cooling pad that adjusts angles and has a camera for like I think 25bucks Buy it now free shipping.. I couldnt use it because I have a a keyboard and mouse for mine and there is no room on the table... I saw Some realy good USB Speakers for under 10 bucks today....
laptop cooling pad
XPS cooling Overclocking & Cooling
Fan cooling Overclocking & Cooling
Laptop Cooling Fan Vista General
Cooling fan on Toshiba laptop Vista hardware & devices
