Solved Overclocking? Really Worth it? (results from 2 PC's)
nostaw5
"POW" Ur dead
Power User
Ok this was originally a long post to write and i accidentally clicked BACK when i was going to publish.:mad:
basically i got 2 pcs, a laptop and a desktop, and i overclocked them.
Both had DDR2 667MHZ, C2D cpus and stock gpus.
I overclocked and got lower fps in games, longer boot times and increased heat.
Cpu-z also detected my desktop memory was at 233Mhz ddr and 466Mhz DDR2.
So that means overclocking reduces performance. I could see my pc stuttering on Plants Vs Zombies when overclocked from 2.4GHz to 3.7GHz. 2.4GHz ran smooth 3.7Ghz was like grinding sand paper along sharp rocks.
The post that was original had more results but im not going to spend another 1 hr of my day writing it out again and getting a sore wrist.
    Custom Gaming Rig 780G
    AMG Athlon II X2 255 3.8/2MB/2500MHz 45nm AM3
    Gigabyte GA-MA78LMT-S2 AM3, Core Boost, Ultra Durable 3
    2X 4GB Kingston DDR3 1066MHz @ 1666MHz Dual Channel
    HIS HD Radeon 7770 GHz Edition iCooler Core: 1000MHz
    Realtek HD Audio
    Dell E2311H DVI/VGA 5ms response, Full HD
    1920x1080 @ 60Hz
    320GB Seagate Barracuda 7200.02 SATA II
    Cooler Master Extreme Power Plus 700w
    Lian-Li PC-6010 With Side Window
    Aywun A4 80mm fan
    Logitech K120 Wired Keyboard
    Logitech K120 Wired Mouse
    802.11B/G/N 17Mb/s
    AMD Catalyst 12.6
    Thomson A/B/G/N Router
    LiteON CD/DVD Player
    GAME PERFORMANCE:
    Battlefield 3: 41 FPS High 1x AA @ 1280x720
    Mass Effect 2 and 3: 60 FPS Highest 4x AA @ 1920x1080
    Counter Strike Source (and other Valve games):
    300 FPS (max FPS in game) Highest settings 8x AA 16x AF @ 1920x1080!!!
Over clocking a laptop is not recommended.
Those who have over clocked a desktop have shown some improvement.
Just watch the temps as you increase speed so goes the the temps. IMHO
    HP Pavilon Elite
    ASUS eK Berkeley
    That's where I keep my beer
    MS WIRELESS
    MS WIRELESS
    AT&T Uverse DSL
I know it is not recommended but i do what i want to do. If i want to overclock a laptop i will.
Yes depending on hardware some will see an improvement. But my results show they dont.
EDIT: As i said i have been overclocking and testing clocks for over a year now.
Cheers
    Realtek HD Audio
    1920x1080 @ 60Hz
    Aywun A4 80mm fan
    802.11B/G/N 17Mb/s
    AMD Catalyst 12.6
    GAME PERFORMANCE:
Of course you may do what you want.
I was just offering some advice not giving you a lecture.
Just don't want you to mess up your computer that you spent hard earned money on.
    HP Pavilon Elite
    ASUS eK Berkeley
    MS WIRELESS
    MS WIRELESS
    AT&T Uverse DSL
I know you were giving advice but i keep hearing NOT RECOMENDED FOR LAPTOPS. Its true though. I do things more careful than people think. And by the way
LAB RAT #2 was made with Pretty cheap parts!
Thanks for the advice.
    Realtek HD Audio
    1920x1080 @ 60Hz
    Aywun A4 80mm fan
    802.11B/G/N 17Mb/s
    AMD Catalyst 12.6
    GAME PERFORMANCE:
But another problem is that you overclocked far too much. If you had overclocked less, you probably would have achieved better results.
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    1 x 640Gb (SATA 300)
    1 x 1Tb (SATA 600)
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Ok so i read the post by niemiro and ran a test with lab rat #2 (desktop). I did a small 3.0GHz to 3.2GHz and still had lower results. So then i did 3.GHz to 3.4GHz to see if i was overclocking too low. NO! still lower... so i tried 3.0GHz to 4.0GHz and... that wasround the same of 3.0GHz AND temps werein the 70's to 80's C.
    Realtek HD Audio
    1920x1080 @ 60Hz
    Aywun A4 80mm fan
    802.11B/G/N 17Mb/s
    AMD Catalyst 12.6
    GAME PERFORMANCE:
I was thinking like 2.5 - 2.6GHz.
    Dell XPS 420
    Stock Dell 0TP406
    1 x 1Tb (SATA 600)
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Overclocking is not worth it in my opinion unless you have high end hardware. Small overclock`s are definetly not worth it. As for laptops, they have very stringent heat and power limitations because of the design of the case and cooling.
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Logik
    Technika TKOPTM2
    Creative Inspire 7.1 T7900 Speakers
    Trust Graphics Tablet
i agree with roy69. Besides where did you get 2.5GHz from??? i had stock 3.0GHz. But 2.5 to 2.6 thats hardly and overclock. More like a.... babyclock.
    Realtek HD Audio
    1920x1080 @ 60Hz
    Aywun A4 80mm fan
    802.11B/G/N 17Mb/s
    AMD Catalyst 12.6
    GAME PERFORMANCE:
I can tell you most likely why your overclock did worse.
Its temperature, all cpus when you get above a certain temp start to slow down to maintain a proper temp. They either cut the multi down or shut a core off. Overclocking ALWAYS produces alot more heat, and managing gthat heat is the biggest part of overclocking.
I can show plenty of yes overclocking is 100% useful., all my cpus are overclocked. My q6600 is only at 2.9Ghz, but it can be 97% astable at 3.1Ghz, and my i7 950 is running zat 4.0Ghz. I can stable it at 4.15Ghz but don't like running 80's C.
Honestly, I find it alittle suspect you got a 1Ghz overclock on a 775 chip without a serious cpu cooler.
775 cpus peak up around 65-70C before they start acting up and shutting down.
And if overclocking safely wasn't worth it, they wouldn't make faster chips, or now make 2 versions of the 1155 cpus.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
Thanks for your response.
My 775 results for intel core 2 duo show that stock 3.0GHz runs around 40c while 3.4/7/9GHZ run about 58c. monitoring temps i have never gone over 74c idle 81c playing plants vs zombies!!!
My socket p t7100 runs at stock 1.8GHz and thats in the 50's. this is a laptop. Overclocked to 2.4GHz the temps rose to 70c.
i would not think temp is an issue for the desktop WITH an INTEL STOCK cpu cooler running ASUS Q-Fan on SILENT!!!
:D:D:huh::(;):sick::huh::mad::cry::p:o;):geek::rolleyes::shock:
    Realtek HD Audio
    1920x1080 @ 60Hz
    Aywun A4 80mm fan
    802.11B/G/N 17Mb/s
    AMD Catalyst 12.6
    GAME PERFORMANCE:
Yha that is a bad thing... those are where the cpu starts throttling.
I run a huge heat sink on my q6600 tyo keep it low at 3.0+ Ghz
The stock setup is pure garbage.
You said that you had stock 2.4GHz, not 3.0GHz, and you don't seem like the sort of person to underclock...IMO. It seemed that you were saying that a massive overclock worsened things. A very good experiment would have been to work upwards, and find out where it changed from faster to slower. And for that, you must start at 0.1GHz more than stock, and work upwards in that step.
    Dell XPS 420
    Stock Dell 0TP406
    1 x 1Tb (SATA 600)
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
Yup they really are [h]ard there.
I'm on there too.
