CPU Fan
I have a AVC DS09225R12EPO58 12v-0.1A CPU fan of the sealed hydraulic bearing type, with a four pin mother-board plug. It is sandwiched between a cooper tube and fined type heat-sink, cooling a Pentium D 2.80Ghz. on a Medion PC with MSI Mother-board, This fan is so noisy and vibrates, there is no oil point under label. What, would be a good replacement fan to fit this heat-sink.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
