Solved My Laptop is Overheating
I got a Acer laptop and I know the cooling fan has been busted a while, I have been using a chiller pad single fan, but it still is overheating...well at least to the touch... I did also have a small fan blowing over the keyboard too but that has also burnt out due to it being overused..... I know there is a temp alarm software, I seen the links for it here, but I cant find it..... I am getting a chiller pad 2 fan tommorrow from ebay 1 dollar 1.60 shipping, but it wont be here for 3 to 4 weeks....
After this conversion I will open up my laptop and see if it needs cleaning..... If so I will do that, I dont have the canned air sio I will use my own air........BLOW HARD....
See if that helps. If someone can send me the link to the core temp software it will be appreciated....
Thank you
    Acer Aspire 5315
    2 gb
    C drive
    D Drive
    Standard Acer Aspire Case
    Cooling Pad and USB Desklamp/fan combo
    DSL 20mb/s
    I run a 60watt speakers from my headphone jack, and I got 10port USB HUB USB Wireless adapter foer the internet
You need to test with speed fan, Ill get the link.
http://www.almico.com/speedfan.php
There are others here that prefer other software. Their opinion is no better or worse than mine, You must make the final choice.
Noname.jpg Here is my temp...im sure it is a little better after I blew out the vents....
    Acer Aspire 5315
    2 gb
    C drive
    D Drive
    DSL 20mb/s
I got the temp down a bit, and the fan is working.... I need to know how to configure the speedfan to cool my computer better.. I dont know my clock etc and the settings I need to work it right....
I cleaned out the dust from the vents and fan with a brush and blowing into a straw...(I got no compressed air except in my lungs lol....
Also What is the Ideal Temp for a laptop????? Acer Aspire......Vista
    Acer Aspire 5315
    2 gb
    C drive
    D Drive
    DSL 20mb/s
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
I couldnt find mine on there I got intel celeron 540 1,86 ghz
    Acer Aspire 5315
    2 gb
    C drive
    D Drive
    DSL 20mb/s
    LENOVO 64734VM
    15 inch
    External Speakers
how do I fd out more information on my cpu and motherboard...????? I don't know where to look to find out model numbers????
    Acer Aspire 5315
    2 gb
    C drive
    D Drive
    DSL 20mb/s
K got it, sorry about delay of reply...been busy.... I got temp down a bit.. :D
    Acer Aspire 5315
    2 gb
    C drive
    D Drive
    DSL 20mb/s
I dont know how to get configuration and ticket number......
    Acer Aspire 5315
    2 gb
    C drive
    D Drive
    DSL 20mb/s
I guess if I got it cooled withiout having to setup config man I should be fine.... As it seems I got it cooled down quite a bit33.jpg
    Acer Aspire 5315
    2 gb
    C drive
    D Drive
    DSL 20mb/s
That looks better
I dont trust that...... use coretemp.
Core Temp
30C at load is extremely low. I'd expect 40-45 on a laptop cpu.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
I found out why the famn on my USB LED Light/Fan combo isnt working..... Turns out a wire is broken.... Lucky My Sister in Law Dragged me to Target tonight and I bought a 6.99 dollar fan 4inch silver Room Essentials brand.. I think this brand is exclusive to Target..... Works great.. I use it on myself and my computer when I am not using it... AAAAAAHHHHHHHHHH Breeze...lol:D:):cool: Summer here in AZ is bad, gets really hot, last year it got in eccess of 128 degrees f...50 deg C.....Too hot....... I am hoping the combination of my fan and the 2 fan cooling pad I bought off ebay will keep my baby cool and sweet running...
    Acer Aspire 5315
    2 gb
    C drive
    D Drive
    DSL 20mb/s
Auto settings in NVIDIA control panel are those which control the temperature of the system. It will check the fans revolution per minute and temperature. Actually it is always better to keep your system in an air-conditioned room which won’t result in overheating. By installing the case fans, it will divert heat out of your computer and increase the air-flow.
Get more information :
ACER Aspire 5004WLMi Laptop overheating - Microsoft Answers
Hope this information helps you.
