Synch issue - big problem!
  1. #1
    jad Guest
    Hi all
    I have a user that is setup to synch his laptop with our SBS server. He has
    been happily doing this for a few years. Last week he said that he has been
    having problems synching for the last 3 months!!!! So now I have a situation
    where I need to re inialise the cache - but this will remove the ost files
    on the laptop and effectively he will lose all the work that he has done in
    the last three months.
    I have a feeling that the only thing that can save these files is to search
    for all files modified in the past three months (whilst he is offline) and
    the open each one and save a new copy to the local drive. Then we can put
    all of new docs in a seperate folder on the server and then re initialise
    the cache and re synch.
    Any comments or any other ideas??
    thanks
  2. #2
    Larry Struckmeyer[SBS-MVP] Guest
    Re: Synch issue - big problem!
    Hi:
    The nomenclature OST is normally reserved for the cached copy of the users
    exchange mailbox that is kept on the local computer for off line use, such
    as travel or server unavailable for whatever reason.
    Off line files is normally used to mean a copy of the users "my documents"
    folder that is stored locally so that the user can read and modify word and
    excel docs while away.
    But, just to be safe, to the date search and determine what user documents
    exist on the notebook then simply copy them out to a new folder so you know
    where they are. Look for matching, similiar documents on the SBS. Backup
    both sets to a known safe location with different folder names. After that,
    you can't hurt anything.
    Larry
    Please post the resolution to your
    issue so others may benefit
    Get Your SBS Health Check at
    www.sbsbpa.com
    > Hi all
    > He has
    > been
    > situation
    > files
    > done in
    > search
    > and
    > put
    > initialise
    > thanks
Synch issue - big problem! problems?
how do I synch windows mail calendar with iphone since Outlook is only option for calendar synch cori traub Vista mail 1 01 Mar 2009
Another time synch problem Steve E. Vista General 2 14 Apr 2008
Will not Synch jackeen Live Folder Share 3 20 Mar 2008
Synch - What to do? David Crisp Vista General 0 09 Apr 2007
Synch Ian Vista performance & maintenance 0 26 Mar 2007
