"Gitendra" <c2gaustralia@newsgroup> wrote in message
news
ABCF76E-4AA8-4B4B-A945-4C3CA1A37122@newsgroup
>I have one Windows 2008 Standard Server with two NICS:
> NIC1: LAN 192.168.200.1
> NIC2: WAN 10.200.200.2
> DNS, DHCP, AD, Network Policy & Access Services are installed. All seems
> to be working fine.
> PPTP VPN works fine through NIC2.
> Then I installed the Squid Caching Proxy and it seems to bind to NIC2. So
> on the LAN clients I have to point the proxy to 10:200:200:2:3128 to get
> it to work. So I tried another proxy called "FreeProxy", again it binds to
> NIC2. Other than that it all seems to work.
> Have I done something wrong in the server setup, shouldn't the LAN clients
> point to 192.168.200.1:3128. Will I start to have problems?
> Any help would be appreciated. Thanking you in advance.
> Regards
> Gitendra
Go into Network Connections windows, Advanced Menu, Advanced Settings,
change the binding order so the internal NIC is the first in the list.
Ace
This posting is provided "AS-IS" with no warranties or guarantees and
confers no rights.
Please reply back to the newsgroup or forum to benefit from collaboration
among responding engineers, and to help others benefit from your resolution.
Ace Fekay, MCT, MCTS Exchange, MCSE, MCSA 2003 & 2000, MCSA Messaging
Microsoft Certified Trainer
For urgent issues, please contact Microsoft PSS directly. Please check
http://support.microsoft.com for regional support phone numbers.
