running DHCP and WDS on same server
  1. #1
    Bonno Bloksma Guest
    Got no answer in the MCITP group itself so I'm asking here.
    Studying for the 70-649 I am looking at the situation where there is a DHCP server and WDS on the
    same server. Situation is either a non-MS DHCP server or using wdsutil to manualy install wds.
    Supposedly now the wds and dhcp are fighting over port 67 and I am supposed to disable listening to
    port 67 "on the server" and enable option 60 on the DHCP scope.
    ----------<quote>-----------------------------
    If you are running Windows Deployment Services and a non-Microsoft DHCP server on the same computer,
    in addition to configuring the server to not listen on port 67, you will need to use your DHCP tools
    to add Option 60 to your DHCP scopes.
    From http://technet.microsoft.com/en-us/l..._ConfiguringDS
    Aparently "the server" is meant to be the DHCP service and not the Windows server which had me
    stooped for a while.
    But then what? Who is handling the dhcp request of the (PXE) client?
    Where can I read what happens?
    I'm assuming something like this but I'de like to know:
    Client sends a DHCP discover broadcast on port 67 in order to get an ip-number.
    The WDS service listens on port 67 and picks it up.
    SOMEHOW the WDS service hands it over to the DHCP service, but how?
    The DHCP service handles the request.
    The DHCP service also sets option 60 to.... what?
    The client now has an ip-number and tries to contact the pxe server on port 4011. Something in the
    option 60 tells it to go to the same server which.... is the default as far as I know.
    The wds service responds to the pxe request and from there on it's straight forward.
    What am I missing? Where can I get a better explanation?
    Bonno Bloksma
  2. #2
    Meinolf Weber [MVP-DS] Guest
    Re: running DHCP and WDS on same server
    Hello Bonno,
    See here about the PXE Boot process in chapter 5:
    http://www.microsoft.com/downloads/d...displaylang=en
    Best regards
    Meinolf Weber
    Disclaimer: This posting is provided "AS IS" with no warranties, and confers
    no rights.
    ** Please do NOT email, only reply to Newsgroups
    ** HELP us help YOU!!! http://www.blakjak.demon.co.uk/mul_crss.htm
    > Hi,
    > DHCP server and WDS on the same server. Situation is either a non-MS
    > DHCP server or using wdsutil to manualy install wds. Supposedly now
    > disable listening to port 67 "on the server" and enable option 60 on
    > the DHCP scope.
    > From
    > http://technet.microsoft.com/en-us/l...0).aspx#BKMK_C
    > onfiguringDS
    > ip-number.
    > as far as I know.
    > straight forward.
    > Bonno Bloksma
  3. #3
    Bonno Bloksma Guest
    Hi Meinolf,
    Thanks, that makes is somewhat clearer. I've added a comment to the original technet document.
    Now all I need to figure out is what that option 60 is supposed to look like.
    Bonno
    >> Hi,
    >> the DHCP scope.
    >> From
    >> onfiguringDS
    >> ip-number.
    >> as far as I know.
    >> straight forward.
    >> Bonno Bloksma
How to delay Server 2003 DHCP responses on second server? Leythos Server General 1 03 Feb 2010
DHCP Client not running boxersallover General Discussion 0 08 Nov 2009
DHCP Client is not running Tom Jones Vista networking & sharing 2 29 Jul 2009
DHCP Client is not running Tom Jones Vista General 3 28 Jul 2009
PXE Server on Vista w/ DHCP Server supanatral Network & Sharing 0 20 Jul 2009
