br> br> |
| | Thread Tools | Display Modes |
| Junior Member Rep Power: 7 ![]() | Can't Get Microphone to work Well I have a Vista 32-bit computer my sound card driver is Realtek HD Audio Manager 6.0.1.5322. Well I just a game called Counter-Strike and wanted to use my microphone well guess what it doesn't work. Not just for the game but for the computer i tested on the windows sound recorder, and tried on the Control Panel\Ease of Access\Speech Recognition Options set up microphone not success. Someone help me please also its not muted. Raised its boost to 20+ and went to speakers properties level tab and maxed all th sound thingys. Please help ASAP! |
| ɠɛɐǨ ![]() ![]() ![]() Rep Power: 110 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() | Re: Can't Get Microphone to work Yeah I had some problems using a mic with vista running css too...Im ingame atm but it should be short and sweet..... There are 3 things to check 1. check the mic is not identically named to any other mic and set as default 2. make sure the volume of the mic itself is turned all the way up (some programs mute it again after using it) and not turned up under the speakers in volume. 3. check the realtec website for the latest drivers or try another mic to make sure its working. |
| Display Modes | |
| Microphone does not work | kokojoe44 | Vista hardware & devices | 4 | 07-06-2008 08:10 PM |
| Microphone doesn't work when plugged in | cauliflower | Vista music pictures video | 10 | 02-10-2008 12:08 AM |
| Getting My Microphone to Work!!!?????????? | DarkCircle | Vista hardware & devices | 1 | 01-19-2008 09:22 PM |
| Microphone On Laptop dont work | Emileyjean | Vista music pictures video | 0 | 11-11-2007 11:12 PM |
| My Microphone doesnt work anymore | Trevor Storms | Vista hardware & devices | 6 | 06-26-2007 05:44 AM |
