br> br> |
| | Thread Tools | Display Modes |
| Member ![]() Rep Power: 17 ![]() ![]() ![]() ![]() | Is it possible to have some sort of 5ch stereo? My denon avr3802 has a mode of 5ch stereo, which i REALLY love.... i am wondering if there is a way, driver and what not, that this could be accomplished... I have an nf680i with the internal audio. i have checked the speaker fill but it does little. What i want is to hear the same out of my front speakers than my back speakers and have a "surround" sound but that is stereo. Or that you hear the dialog out of the back speakers also.... Hope i made myself clear. Thanks |
| NoNonsense ![]() ![]() Rep Power: 23 ![]() ![]() ![]() ![]() ![]() ![]() | Re: Is it possible to have some sort of 5ch stereo? Depends which music software and hardware you are using as to what you hear really. I use foobar2000 and the kernel streaming plugin. That puts out music to all my 7.1 speakers via digital or normal ouput. ASIO plugin will also do the same thing. I think that Winamp will do the same, but I don't really use it so cannot comment much on that. Windows media player is useless with no decent plugins, so don't even try that one! |
| Member ![]() Rep Power: 17 ![]() ![]() ![]() ![]() | Re: Is it possible to have some sort of 5ch stereo? would those plugins work with windows media player and/or media center? Thanks |
| NoNonsense ![]() ![]() Rep Power: 23 ![]() ![]() ![]() ![]() ![]() ![]() | Re: Is it possible to have some sort of 5ch stereo? No mate. As I said, WMP is useless for the type of playback you require. |
| Display Modes | |
| No Mic through Stereo Mix or speakers! | Hooligal | Sound & Audio | 4 | 07-01-2008 06:44 AM |
| Re: Can I sort within a sort, in folder view (eg., Name, Date) | Baffin | Live Mail | 0 | 12-09-2007 02:44 PM |
| stereo mix :( | K- | Vista General | 2 | 08-19-2007 04:58 AM |
| Sort by name doesnt sort correctly in my opinion | douglasgblake | Vista file management | 5 | 08-08-2007 09:17 AM |
| Stereo Mix | Trini | Vista General | 0 | 02-16-2007 11:21 AM |
