Xtreme Fidelity X-FI And DVD ROM
DjLevel9
Banned
:party:I Have The Xtreme Fidelity X-Fi sounds Best On X-Fi DVD & ROM.
for those who been haveing the same problem Installing this on windows Vista 32 7 64 .
I Found the soulution To Use the origonal DVD_CD + ROM
That came with the sound Card everything works the 7-1 Speaker Setting work the way there supposto If You Run Them Through you're stereo system you have to have 6-1 or 7-1 sourond sound system in order for this to worked.
(1) Install The Vista Web updated Driver Go through the Instilation Instructions it will come up you have a prievious version of creative lab Say yes to Uninstall of it if it comes up.
it will asked you take the <Full> Instilation-The follow Instructions, it will ask you to reboot so setting's will take effect...
When you computer reboot's back to the desktop ..Put in The Origonal DVD-CD That came with you're Sound Card here's The Fun part.
Click the Install when the DVD=CD Bring's Up The Creative lab Instilation.
INSTALL : It it will come up with a Driver already there click yes to Uninstall this file go through the proceedure .
you will be aible to keep the Driver is the Same But To Vista it will Think You're You're Installing The vista Logo Driver from The web Site.
A Few Months back micro soft came up with a Compatible Driver For All OS versions Of windows Instilation They Sent it out By mastake i found it today on my computer To long to Explaine but it's there.
But Vista Protocal Protection Security File Comes into place all the when this file is activated by an Instilation it blocks the Vista Protection file for Creative lab and think's the version is installing under windows 2000 some printer drivers where like this for Xp pro as well. if you couldn't find an update driver.
Now You can INSTALL The Origonal Divers that Came with this DVD nd use the DVD DEMO-DISK as well there are extra drivers built in for the 3D Drivers and .
when thats all done Go through the set up Audio Creation Mode set up here's way of tweaking the creative sound card to Sound Great I like it too me a bit to figoure this out Print this out it's gonna come in Handy.
(1) Ib Audio Creation Mode Change the 48 HZ Frequency to 98 HZ And go into the Setting Mode Bottom left - bring you're Mouse Currsor over to The Game Mode here;s where you Tweek You Card to The Best preformance possible.
Make Sure the 7-1 Is Clicked On In Speakers . Crystal at 50% Xpand Mode turned On Bass Optimizer Turned On
There also a setting;s for the Speakers Setting the distance for the speakers it's there as well I use The max setting's is 30 for the left and right use the max for all :)
go though the testing Mode's once you have all this done Hit the Mode back To Audio Creation Mode Make Sure on The Left side Bottom it says 96 KHz Kick okto hold that setting for this mode.
you will see the Input Dials there are 6 rows of the make sure each is set to the Middle Ballance Row As well.
The Mute Change them All To Solo till All The Green Lights Up on each.
Front L/R Blue <-------All the way accross all buttons
Rear/L/R Blue ,,The Same
Front C/Sub Blue <----The Same
Rear C/Top Blue <-----The Same
Side L/R Blue<------The Same
There's A lock Button Hit to lock thease Setting's you will have to do this just for the Blue settings when you reboot you're computer thats and hit Lock and Minimize that window for the Audio Creation .
Now i hope this was Help Full a Lot of people don't go into detail I like to make sure they Understand how to use there software and the Equipment the Install .
I Covered Stuff Vista And Creative Labs Didin't Cover.
(2) Install the update From Creative Lab ALchemy X-Fi
yoou can use this as well. but not nessarly since you're DVD rom had all this in the first place Daahhhhhhhhhh I said to Creative labs And Microsoft they Should Be Smack for Not Giveing The propper Information But I guess it's not there concern or Priority To fix what needs to be Fixed first. lol
