| | #11 (permalink) |
| Windows Vista™ Ultimate x64 | Re: Problem in mp3 files details I think that Windows Media Player automatically names everything. If you disconnect from the Internet it should change but when you re connect it will probably change back. I think its like track ID and scans it and names it whatever song it is. |
| | #12 (permalink) |
| Vista Ultimate x64 | Re: Problem in mp3 files details |
| | #13 (permalink) |
| Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1.... | Re: Problem in mp3 files details Windows Media Player (or, WiMP, as I call it) has an option to automatically connect to the Internet to update your music files . Turn that off and see if it helps. |
| | #14 (permalink) |
| | #15 (permalink) |
| Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1.... | Re: Problem in mp3 files details you cannot run WiMP at all? |
| | #16 (permalink) |
| Vista Ultimate x64 | Re: Problem in mp3 files details With my account it is not possible to run. I click the wmpaler icon but nothing happens. However, If I logon via another account, no problem occurs. I think some registry problems occured in my account. Because accidentally I used CClaener |
| | #17 (permalink) |
| Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1.... | Re: Problem in mp3 files details Make a new profile and copy all your files over to the new profile - it would probably be easier than trying to fix at this point, especially as it runs fine on other profiles. |
| | #18 (permalink) |
| Vista Ultimate x64 | Re: Problem in mp3 files details So now instead of wmplayer x86, I started to use wmplayer x64. |
| Mp3 Files Details Problem | General Discussion | |||
| Get the same details for all folders and files | Vista General | |||
| All files and folders are Music Details template. | Vista General | |||
| Preview of Office files in Details Pane | Vista General | |||
| 5308-64: Find files choose details | Vista General | |||
