br> br> |
| | Thread Tools | Display Modes |
| | #11 (permalink) |
| Newbie | Re: Staticy Sound. i have the same issue, some sounds have a staticness to them, for example if i go into sounds> and play the asstriks sound it will have a static-ness about it. i have swapped the speakers and its the same, also updated reltek drivers to latest ones and no change, i think i am going to buy a sound card and use that instead of the onbaord sound and see how i get on. |
| Display Modes | |
| Onboard mobo sound or dedicated sound card? | grimreaper | Sound & Audio | 2 | 03-15-2008 10:08 AM |
| Sound Problems - Vent, Xfire, Steam voice - no sound | ZebraS | Vista hardware & devices | 2 | 01-02-2008 07:38 PM |
| Setting per Application Sound Output, or Per Sound Type Outputs... | Michichael | Vista General | 0 | 09-24-2007 01:40 AM |
| My Creative Sound Blaster X-FI Sound Card Works Now with Creative's RC1 Device Driver's! I Have Sound! | Kevin John Panzke | Vista General | 1 | 10-14-2006 05:36 AM |
| Vista x64 RC2 - Sound Card/Amplifier - DTS Test Sound (Audigy 2 ZS SPDIF) | Terje Alexander Barth | Vista General | 0 | 10-14-2006 05:13 AM |
