| Welcome to Vista Forums we are your forum to discuss Windows Vista x64 and x86 systems. |
| | Thread Tools | Display Modes |
| Newbie ![]() Join Date: Nov 2007 Vista Business x64
| Swapping Headphones and Speakers help? Hi, I like to use speakers for listening to music/radio and I like to use headphones when playing games (TF2, Counterstrike, etc). It would be really nice if I could swap between the two easily, but I can't seem to sort this out. Before I moved to Vista I could get a signal to both my speakers and headphones at the same time. However, when I upgraded to Vista x64 I also upgraded my motherboard (to a GA-P35C-DS3R) and it now provides Realtek HD audio. However it seems my case only supports AC97. What I would like is either: 1. A physical switch to switch between them (preferred) 2. Both playing audio at the same time I want to buy some Creative Gigaworks T40s to replace my old speakers. Also my old headphones have recently broken so I need to buy new ones. I am looking at some decent gaming headphones - either Medusa 5.1 ProGamer or maybe Sennheiser PC161. (Any better suggestions?). However, the switching thing is the real problem. Considering I am shelling out for new headphones and speakers I don't want to spent a huge amount beyond this - maybe another £50. So, is there some box I can buy? Would moving away from onboard realtek HD audio help? maybe getting a Creative X-Fi card? thanks in advance, Paul |
| Vista Fan ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2007 Vista Home Premium 64bit
| Re: Swapping Headphones and Speakers help? Not sure which country yu are in but in Australia we have electronic stores where you can buy kits to make switches. A couple of years ago I built a switch for a my headphones but it was either one or the other...it was fun to make. |
| Plays with his WEI ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2007 Vista Ultimate x64 SP1
Location: Nooooo Joizeee | Re: Swapping Headphones and Speakers help? I'm thinking along the same lines as Clevo - The quickest solution would be to buy a switch from an electronics store for a few bucks (quid, whatever). A second approach, since your headphones aren't working, would be to buy a USB headset for gaming. Then whether you have extra connections for more speakers becomes a non-issue. Last edited by Scotteq; 03-28-2008 at 08:02 AM. Reason: Spelingg |
| Q6600 SLACR @ 3.2Ghz (8 multi, 400 FSB) DFI LP UT P35 T2R LGA 775 Mobo 8GB OCZ Reaper DDR2 800 C44GK 4-4-4-12 2T EVGA 8800 GTX OC2 1TB Seagate 7200.11 HDD OCZ 900MXS PSU Auzen X-Fi Prelude 7.1/Nakamichi SoundSpace 8.5 CoolerMaster Stacker 835 Zalman PS9500 AT cooler Vista Ultimate x64 SP-1 "I divide my officers into four classes; the clever, the lazy, the industrious, and the stupid. Each officer possesses at least two of these qualities. Those who are clever and industrious are fitted for the highest staff appointments. Use can be made of those who are stupid and lazy. The man who is clever and lazy is for the very highest command; he has the temperament and nerves to deal with all situations. But whoever is stupid and industrious is a menace and must be removed immediately." General Kurt Von Hammerstein-Equord, Truppenführung, 1933 | |
| Enthusiast ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2007 Windows Vista Home Premium x64 SP1
| Re: Swapping Headphones and Speakers help? It's hard for me to tell you exactly where it is, but there should be an option to not automatically mute your speakers when you move to headphones. I know that's available with my XFi, but I doubt that's really an exclusive feature. Try to find something that says "Automatically detect headphones" or something along those lines in your sound options. It might be buried in an advanced settings window somewhere. |
| AMD Athlon 64 x2 6000+, 6GB DDR2 PC6400 (800MHz) RAM, 2x Sapphire ATI Radeon HD 3870 512MB GDDR4 TOXIC Edition (Crossfire Mode), ASUS M2R32-MVP Motherboard, Creative SoundBlaster X-Fi XtremeGamer, Western Digital 250GB HD | |
| Re: Swapping Headphones and Speakers help? So right now I am favouring the switch approach. I assume an electronics shop would stock a headphone jack splitter switch? My only question with this approach is if I decided I wanted to buy the Medusa 5.1 headset, where I have to deal with the 5.1 cables - is this still supportable? cheers Paul |
| | #6 (permalink) |
| Re: Swapping Headphones and Speakers help? Well, I'm doing it with a front panel, so I'll have to play with the card when I'm near it and have some time. Hopefully by this afternoon. If you don't have an option of seperate plugs, you might just want to get a stereo splitter. It'll save you lots of money, and if your goal is to always have simultaneous playback, it should work just fine (some minor quality losses, but nothing big). |
| | #7 (permalink) |
| Maniac ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2008 Vista Ultimate x64
Location: Jacksonville, Florida, USA | Re: Swapping Headphones and Speakers help? Just do it the simple way. Buy 3 Y adapters and have the headphones plugged in at the sametime. I have the Razer Barracuda 5.1 headset plugged into my soundcard at the same time as my speakers. Works just fine. Just turn off the one you don't need at the moment. They would also play audio at the same time. |
| | #8 (permalink) |
| Re: Swapping Headphones and Speakers help? Yeah, I think that's the best way. I wasn't able to get a real good reproduction using multiple ports on the back. I can do it on front panel, but if you don't have one, that's not helpful to you. Sorry. |
