| vista home 32bit | No sound at all Hello, I recently purchased a new desktop computer and it came with an on board sound card, and it seems a lot of people are having problems with it (realtek). I was wondering if i could get any help, anything at all would be greatly appreciated. Now, when I plug my speakers into the rear panel, realtek device manager still shows that I have not plugged anything into the back jack, and I have checked about 10 times to make sure it is in the right hole, this is also the issue with my microphone, when I try to configure my speakers, it shows a red "x" and says "not plugged in" I don't know what the issue may be, it does the same for microphone as well, and I can't figure out how to fix this. Also the "configure" and "set default" button's are grayed out and I can't click them. Also I am trying to use analog speaker's if that makes any difference with responses. P.S It does the same for the headphones jack in the front of the computer as well. When I do plug in my headphones all I hear is a fuzz, and with the speakers and the rear jack, I hear some what of what sounds like a dog whistle. Here is a screenshot I took maybe it will help. ![]() |
| Vista Home Premium 64bit | Re: No sound at all Do you get any sound at all? Like when the system boots into windows and you can hear the welcome sound? I don;t get a panel for my headphones and they work fine. Right click on the panel that says "speakers" and follow the test in that. Do the same for all the other panels. Get back to us with the results... |
| vista home 32bit | Re: No sound at all No, I can't even hear the welcome sound, and even when I try to test the speakers it wont let me, it seems it has it completely disabled some how and I don't know how to enable it, I took another screen shot if that helps. I also think the only problem I have is just getting the speakers to enable, if I could do that I have a feeling it will work. ![]() |
| Vista Home Premium 64bit | Re: No sound at all I know that this is going to sounds silly but can you double check that your speakers are plugged in not only to the back of the PC but also to some power ( if it comes with a plug to the mains power) Do you have a friend you can borrow a set of speakers from for testing. I want to eliminate faulty speakers or faulty: Speaker inlet ( the boards where you plug the speakers into) or Sound card |
| vista home 32bit | Re: No sound at all I borrowed my friends speakers and still no luck, I had an old sound blaster live sound card in my old machine and I threw it in this one, and I have sound for now, only problem now is that the front jack can't be used for headphones so I really want to fix the on board one. |
| | #6 (permalink) |
| Vista Home Premium 64bit | Re: No sound at all I borrowed my friends speakers and still no luck, I had an old sound blaster live sound card in my old machine and I threw it in this one, and I have sound for now, only problem now is that the front jack can't be used for headphones so I really want to fix the on board one. |
| | #7 (permalink) |
| Home premium 32 bit, SP1 | Re: No sound at all Hello, I recently purchased a new desktop computer and it came with an on board sound card, and it seems a lot of people are having problems with it (realtek). I was wondering if i could get any help, anything at all would be greatly appreciated. Now, when I plug my speakers into the rear panel, realtek device manager still shows that I have not plugged anything into the back jack, and I have checked about 10 times to make sure it is in the right hole, this is also the issue with my microphone, when I try to configure my speakers, it shows a red "x" and says "not plugged in" I don't know what the issue may be, it does the same for microphone as well, and I can't figure out how to fix this. Also the "configure" and "set default" button's are grayed out and I can't click them. Also I am trying to use analog speaker's if that makes any difference with responses. P.S It does the same for the headphones jack in the front of the computer as well. When I do plug in my headphones all I hear is a fuzz, and with the speakers and the rear jack, I hear some what of what sounds like a dog whistle. Here is a screenshot I took maybe it will help. ![]() ![]() Here is a link to Microsoft Help & Support -- Tips for fixing common sound problems. There are several categories. Pick the one(s) applicable to your problems. Windows Vista Help: Tips for fixing common sound problems |
| distorted sound in vista/createiv x-fi titanium sound card | Sound & Audio | |||
No sound when playing music or video, but internet sound works fine | Sound & Audio | |||
| Setting per Application Sound Output, or Per Sound Type Outputs... | Vista General | |||
| My Creative Sound Blaster X-FI Sound Card Works Now with Creative's RC1 Device Driver's! I Have Sound! | Vista General | |||
| Vista x64 RC2 - Sound Card/Amplifier - DTS Test Sound (Audigy 2 ZS SPDIF) | Vista General | |||
