| | #31 (permalink) |
| Member | Re: Vista Codec Pack - 32bit & 64bit Media Player Codecs Thanks a lot man! |
| | #32 (permalink) |
| Antidisestablishmentarian | Re: Vista Codec Pack - 32bit & 64bit Media Player Codecs VCP 4.7.3 released |MG| Vista Codec Package 4.7.3 Final VCP x64 Components 1.5.2 released |MG| Vista Codec x64 Components 1.5.2 Final Changelog http://shark007.xpdnc.org/description.txt current changelog: - update ffdshow rev 2080 - update Gabest filters rev 729 - improve M2T support in Vista WMP11 - Fix audio in MKV some other audio formats too - remove PLS support (see homepage Tools section) - remove SPDIF config tool (see homepage Tools section) BTW, this version fixes AC3 audio playback in WiMP and WMC, for those of you still having issues with videos like .MKVs. |
| | #33 (permalink) |
| Member | Re: Vista Codec Pack - 32bit & 64bit Media Player Codecs dmex Have had problems with W M P for ages ,not playing etc been to numerous forums tried uninstalling everything. Saw your post about codecs, downloaded it sorted !! Thanks for the info. From start to finish took me about 15 mins . All ther best arry |
| | #34 (permalink) |
| m@thue | Re: Vista Codec Pack - 32bit & 64bit Media Player Codecs Does the GSpot program actually work in Vista cause the site doesn't say... |
| | #35 (permalink) |
| ɠɛɐǨ | Re: Vista Codec Pack - 32bit & 64bit Media Player Codecs |
| | #36 (permalink) |
| m@thue | Re: Vista Codec Pack - 32bit & 64bit Media Player Codecs Thanks dmex. (i tipped your scales (hint, hint, nudge, nudge)) |
| | #37 (permalink) |
| Eye know, eye know | Re: Vista Codec Pack - 32bit & 64bit Media Player Codecs There's a new Beta package available: Download Vista Codec Package 5.0 Beta 1 / 4.7.3 - With this package installed, you shouldn't need to install any other codec or filter - Softpedia |
| | #38 (permalink) |
| Master | Re: Vista Codec Pack - 32bit & 64bit Media Player Codecs Thanks for the info smarteyeball |
| | #39 (permalink) |
| Eye know, eye know | Re: Vista Codec Pack - 32bit & 64bit Media Player Codecs No worries mate. |
| | #40 (permalink) |
| Newbie | Re: Vista Codec Pack - 32bit & 64bit Media Player Codecs Hi - sorry dumb question coming .... will downloading the codec allow me to play a .ram file in wmp v11 - I have no idea if it's 32 or 64 bit, can't find anything that tells me. |
| DVD player/codec pack needed | Software | |||
| PLEASE HELP!!!windows media player 11 codecs | Vista General | |||
| Codecs on windows media player (.MOV) | Vista music pictures video | |||
| avi codec for Window Media Player on Vista | Vista music pictures video | |||
| Windows Media Player, streaming and Codecs | Vista music pictures video | |||
