| | #41 (permalink) |
| Eye know, eye know | Re: Vista Codec Pack - 32bit & 64bit Media Player Codecs Hi Moon, It's not a dumb question. I personally don't use Realmedia player so haven't had any .rm/.Ram extensions so I can't tell you if it would work or not. Perhaps someone else who knows could. But here's a link to the VCP developers page, you may find an answer there. Vista Codec Package Homepage (VCP) Good luck ![]() To determine if your running 32 or 64 hit WIN+Pause/Break and you'll find some simple info. |
| | #42 (permalink) |
| ɠɛɐǨ | Re: Vista Codec Pack - 32bit & 64bit Media Player Codecs You can play Realmedia files if you install the seperate VCP RM package ![]() Steven |
| | #43 (permalink) |
| Newbie | Re: Vista Codec Pack - 32bit & 64bit Media Player Codecs Thanks both of you for your replies - I want to try and keep to one player rather than taking up space on my laptop with many packages that I rarely use |
| | #44 (permalink) |
| Tech Help since 1993 | Re: Vista Codec Pack - 32bit & 64bit Media Player Codecs Hi Folks I have used this Vista Codec Pack for 1 year now and it is the Best full codec pack for Vista 32 & 64bit that I've ever found! In fact, if I remember correctly, I think I mentioned this VCP pack some months ago to John and a few others here who had never heard of it, and recommended it to them. Glad to see they've checked it out... ![]() Some info for others - **To make Vista 64bit use the 32bit Media Player by default: Make sure you have the 64bit VCP Tools pack that Dmex has linked too at the start, then click Start - All Programs - VistaCodecs - 64bit Tools - Default Media Player & click the "Set 32bit Media Player as Default" icon. This MUST be done twice, don't ask why. This is required if you want to play FLAC files in Vista 64bit. For moonlustie - The RealMedia (RM) package for VCP doesn't add the full RealMedia Player, it's a plugin but it is required if you want to play RealMedia files in WMP. |
| | #45 (permalink) |
| ɠɛɐǨ | Re: Vista Codec Pack - 32bit & 64bit Media Player Codecs The latest Media Player Classic builds can be found here: http://mpc-hc.sourceforge.net/ This project is based on the original "Media Player Classic" and was created after Gabest, the original author, stopped working on it. Several new features have been integrated in this player, such as :
| | #46 (permalink) |
| Newbie | Re: Vista Codec Pack - 32bit & 64bit Media Player Codecs I just installed this codec package on Vista X64 and it play everything I throw at it very smoothly and way better than klite. One thing I'm trying to figure out is how to change the brightness and contrast for certain video files such as avi, mpeg1-2-4, divx...ect. In klite, I could check the overlay filter and change the brightness for a file that is playing but in VCP when I right click on a video all I see is Filters>MPC Video Decoder. I try setting the "video decoder configuration" but nothing changes. Please help me out! |
| | #47 (permalink) |
| Member | Re: Vista Codec Pack - 32bit & 64bit Media Player Codecs Hi there...... I installed and it is almost perfect. The CPU is not having a high usage any more, but the subtitles wont work! They are in the same folder as the MKV movies but does not work. They worked perfect with the K-light =/ I marked "subtitle" in the ffdshow but did not work yet. Thanks. |
| | #48 (permalink) |
| ɠɛɐǨ | Re: Vista Codec Pack - 32bit & 64bit Media Player Codecs Vista Codec Package has been Updated for both X32 and X64 installers ![]() I have updated the links above ![]() 32bit changes include: 5.0.3 changelog: - update ffdshow rev 2364 - update Gabest filters rev 901 - minor revisions 5.0x highlights over 4.x versions: - add several new configuration shortcuts - add support for E-AC3 and Dolby TrueHD audio - add speex audiobook playback support - add Cyberlink MPEG2 codec for DVD playback - update installer icon/graphics/logo - fix RealPlayer website access for all browsers 64bit package changes include: 1.5.6 chagelog: - update ffdshow rev 2364 - update Gabest filters rev 901 - minor revisions Recent changes included but were not limited to: - support for E-AC3 and Dolby True HD and MLP - support for AMR audio (full 3GP playback) - add H264 DXVA support /shortcuts - update installer icon/graphics/logo - enable playback of FLV's /h264 ![]() Steven |
| | #49 (permalink) |
| Member | Re: Vista Codec Pack - 32bit & 64bit Media Player Codecs Someone, please....... How do I solve my subtitle problem?? Thanks. |
| | #50 (permalink) |
| Newbie | Re: Vista Codec Pack - 32bit & 64bit Media Player Codecs I am trying to use the encoder from microsoft for some .asf files so I can make a small music vid. But it says I am missing an audio codec with a code following. The code is 0xC00D0BC2 will this fix the problem? |
| DVD player/codec pack needed | Software | |||
| PLEASE HELP!!!windows media player 11 codecs | Vista General | |||
| Codecs on windows media player (.MOV) | Vista music pictures video | |||
| avi codec for Window Media Player on Vista | Vista music pictures video | |||
| Windows Media Player, streaming and Codecs | Vista music pictures video | |||
