Vista - Urgent Help
Old 05-17-2008   #1 (permalink)
VISTA ULTIMATE 32BIT
Urgent Help
Dear Friends,
I have vista ultimate on intel 102 motherboard. I tried to reinstall the correct codec for vista, Vista_R191.It uninstalled the earlier default driver, rebooted but did not load the new driver. I had downloaded both .exe as well zip file from realtek site.
The error message is of "time out". Can anyone help me solve this problem?
Old 05-17-2008   #2 (permalink)
Vista Home Premium 32-bit & Vista Ultimate 64-bit both Service Pack 2 W7 Pro RTM 7600 32 & 64
Re: Urgent Help
Hi vivek,
When downloading a driver from a website, always select the option to save it to disk. Once it has been downloaded, you can run it from there. The reason why you got a 'time out' error message is because the Realtek download site can be frustratingly slow at times, with a transfer rate that would barely tax a dial-up connection, let alone broadband. There is a new version available, R1.92, link given below for your convenience.
Dwarf
Realtek
Old 05-18-2008   #3 (permalink)
Re: Urgent Help
Hi Dwarf,
thanks for the solution. The error is not in downloading the driver from realtek. error is occuring while running the same from my desktop. Anyways i will try downloading the 1.92 and try with it.
URGENT HELP Vista installation & setup
