| Windows Vista Ultimate 64 bit | Incoming Microphone Sound Problem Ok , all sounds are working except i can't hear any incoming microphone sound, I've try with Msn, Xfire , TeamSpeak and Ventrilo . Im using the integrated sound from the motherboard , is SoundMax Integrated Digital HD Audio, Driver 6.10.2.6110 , I've try reinstalling the driver but it didn't fix anything. ![]() Please if anyone knows anything about this let me know, I used to talk with people over the net about 5 months ago with this same computer and everything worked . Last edited by haxxus; 05-20-2008 at 04:49 AM.. |
| Windows Vista Ultimate 64 bit | Re: Incoming Microphone Sound Problem The problem is i can't hear mono sounds , does anyone know any fixes to mono sound? Last edited by haxxus; 05-22-2008 at 01:59 PM.. |
| Vista Home Premium 64bit | Re: Incoming Microphone Sound Problem I don;t think it's the mono it seems to me to be a seting somewhere. What sort of headset with Mic is it? |
| Windows Vista Ultimate 64 bit | Re: Incoming Microphone Sound Problem is a FATAL1TY CREATIVE headset , but i also plug my speakers and i can't hear any mono sound's. Now i know is the Mono sound , Msn Sound test is mono , seems all sounds i can't hear are mono. Maybe theres a fix i can do to the registry or a sound codec that fixes it? i just install Voice changer 6.0, it has the Option to change audio from Mono to Stereo and only Stereo works. |
| Windows Vista™ Ultimate | Re: Incoming Microphone Sound Problem Hi Haxxus, SoundMAX audio working fine here...Do you have some audio files that you can use to show us what sounds do or dont play properly? Steven |
| | #6 (permalink) |
| Windows Vista Ultimate 64 bit | Re: Incoming Microphone Sound Problem is fixed , i install ac3filter and i can hear all mono sounds now, but ya i had no sound on any software using mono for audio system . |
| no incoming sound on skype | Sound & Audio | |||
| How to change sound that plays on incoming email | Live Mail | |||
| Microphone Sound | Vista hardware & devices | |||
| SOUND ALERT FOR A SPECIFIC INCOMING EMAIL | Vista mail | |||
| Microphone or Sound Input Device Problem | Vista hardware & devices | |||
