Vista - codec problem
Old 05-26-2008   #1 (permalink)
vista 64-bit ulimate sp1
codec problem
here is the error i get with codec 64-bit
Old 05-26-2008   #2 (permalink)
Vista Home Premium 64bit
Re: codec problem
What were you installing exactly...and what problem were you trying to resolve.... or did you just want the codec pack "just in case"
Old 05-26-2008   #3 (permalink)
Re: codec problem
i was trying to install
both
1st
Vista 32bit MediaPlayer & MediaCenter Codecs: (everyone needs this version)
|MG| Vista Codec Package 4.6.5 Final
this one just hung tring to configure space reguirements
then this
Vista 64bit MediaPlayer & MediaCenter Codecs: (64bit users only)
|MG| Vista Codec x64 Components 1.4.5 Final
this is where that error appeared
Old 05-27-2008   #4 (permalink)
Windows Vista™ Ultimate
Re: codec problem
Hi Njnitehawk,
Both programs have been updated this week, the two versions you have are both old versions...I updated the topic a few days ago with the new releases... Vista Codec Pack - 32bit & 64bit Media Player Codecs
Here are the direct links
Vista Codec Package 4.6.6 Final
Vista Codec x64 Components 1.4.7 Final
Make sure you right-click and select "run as admin" and completely uninstall both versions before installing the new ones.
Let me know if it helps.
Steven
Quote  Quote: Originally Posted by njnitehawk View Post
both
1st
then this
Old 05-27-2008   #5 (permalink)
Re: codec problem
dmex
is there an order to install one before the other
Old 05-27-2008   #6 (permalink)
Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1....
Re: codec problem
Yes - Install the 32bit version 4.66 first, followed by the 64bit pack version 1.4.7.
Codec Problem! Sound & Audio
WMP 11 - Codec Problem Vista music pictures video
Encoding Problem: Right Codec? Vista hardware & devices
avi codec problem Vista General
Audio Codec Priority or setting default Codec Vista music pictures video
