| | #31 (permalink) |
| Member | Re: ALC889A, Vista x64, Speaker Fill = rear speakers distorted I just recently upgraded from 2GB to 4GB of RAM on my Vista x64 box and started having sound issues playing Netflix. The sound would crackle and cut out watching videos. At first I though it was a connection issue, but tried WMP and noticed some distortion playing certain mp3s and a little random crackle noise in the background. Re-installing the sound drivers fixed the cutting out, but some mp3s still have a little muffling and distortion. Has there been any real proof that this is indeed a problem isolated to Vista x64 PCs with 4GB of RAM? |
| | #32 (permalink) |
| 64bit noobie | Re: ALC889A, Vista x64, Speaker Fill = rear speakers distorted damn it!! windows 7 also has the same speaker fill. |
| | #33 (permalink) |
| Member | Re: ALC889A, Vista x64, Speaker Fill = rear speakers distorted |
| | #34 (permalink) |
| 64bit noobie | Re: ALC889A, Vista x64, Speaker Fill = rear speakers distorted I sent the feedback. I told em about vista too and how it sucks compared to xp and pulseaudio in linux. Anyways this will no longer be a problem for me. I will buy a x-fi titanium next week after checking its compatibility with windows 7. Windows 7 has improved audio by reducing latency avg and standard deviation. So less chance of skip,crackle pop problem of creative sound cards. |
| | #35 (permalink) |
| Newbie | Re: ALC889A, Vista x64, Speaker Fill = rear speakers distorted That Speaker Fill option works remarcably similar with Dolby Prologic 2 Music 5.1 upmixer..i i guess it`s quite an advanced feature instead of crappy drivers. Could be the biggest thing for audio in vista |
| | #36 (permalink) |
| PC Geek | Re: ALC889A, Vista x64, Speaker Fill = rear speakers distorted wahey, old thread bumpage |
| | #37 (permalink) |
| Member | Re: ALC889A, Vista x64, Speaker Fill = rear speakers distorted Just an FYI, installing Vista SP2 didn't fix this annoying problem. |
| Realtek HD - Rear speaker distortion FIX | Sound & Audio | |||
| how can i use rear line-in port for rear speaker on Intel D945GCPE motherboard | Sound & Audio | |||
| No sound from rear speakers | Vista hardware & devices | |||
| NO sound in rear speakers | Vista music pictures video | |||
| Rear Channel Speakers Not Functioning In Windows Vista With Realte | Vista General | |||
