Mic Boost
Cakewalker
Can someone post the regedit for enabling mic boost for vista ultimate x64? I had it before but then reformatted and lost the directions. Please help and thank you very much.
Hi Cakewalker and welcome to the forums :party:
This is actually easier to do through audio properties. I don't know what audio you have on your system, but the following step by step instructions are for mine and should be easy to adapt for yours. If you want specific instructions, please supply more details of your system.
Dwarf
1) Right-click the speaker icon in the system tray.
2) Select 'Recording Devices'.
3) Highlight 'Microphone'.
4) Click 'Properties'.
5) Select the 'Custom' tab.
6) 'Mic Boost' is on this page. Enable or disable it as required.
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
Thanks for the reply but there is a problem with it. My custom tab does not have the mic boost option. I was actually able to go into the registry and searched for MicBoost and found the reg I needed. It was default set to 0 so I flipped it over to 1 and now everyone can hear me clearly. The location of the MicBoost regedit is:
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Class\{4D36E963-E325-11CE-BFC1-08002BE10318}\0000\Settings
Scroll down on the right hand side and look for MicBoost. Double-click it and put a 1 where there was a 0. Now you have MicBoost and everyone is happy.
Nice find. Ill have to remember that one!
    Dual Core E7200
    Asus P5K
    4GB DDR2 800 SDRAM
    GForce 8600GTS 512mb
    Auzentech XFi Prelude 7.1 on Onkyo605 Rxer
    20" Samsung SyncMaster 206BW
    Sky UK
I can only go as far as
Code:
- I have a 0000 entry (and 0001 - 0004) but none of them have a Settings sub key. In fact, none of them have *any* sub keys.
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech G15 (gen 2)
    Logitech MX Master (shared)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Radeon HD (Embedded)
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
did you try just doing a search in the regedit? Open regedit and hit ctrl-F and type in "MicBoost" one word. That brought it up for me so hopefully it will work for you to. Good luck.
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
