| 32bit | !!!please help. No sound!!! Idk what's going on but i cant hear anything. The speaker icon at the bottom right has a red x on it. When i move the cursor over it, it says, "no audio output device installed." please help me!! Thanks, dre... Specs: Sony Vaio PCG-7113L, Windows Vista 32bit, 2G RAM, 140GB HD, Last edited by DRE910; 07-12-2008 at 05:02 PM.. Reason: I didnt provide specs |
| Windows Vista Home Premium x64 SP1 | Re: !!!please help. No sound!!! Could you provide your system specs? |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: !!!please help. No sound!!! Hello Dre, Here are some usual suspects that you can check until we get more information: 1. Correct audio driver version is installed and shows up in Device Manager as running properly. 2. Speakers are plugged in all the way. 3. If you have a onboard audio chip, then make sure that it is enabled in the BIOS. (Azalia Codec) 4. Volume level is not muted. Shawn |
| distorted sound in vista/createiv x-fi titanium sound card | Sound & Audio | |||
No sound when playing music or video, but internet sound works fine | Sound & Audio | |||
| Setting per Application Sound Output, or Per Sound Type Outputs... | Vista General | |||
| My Creative Sound Blaster X-FI Sound Card Works Now with Creative's RC1 Device Driver's! I Have Sound! | Vista General | |||
| Vista x64 RC2 - Sound Card/Amplifier - DTS Test Sound (Audigy 2 ZS SPDIF) | Vista General | |||
