Vista - X-Fi!
Old 07-19-2008   #1 (permalink)
Vista Home Premium 64Bit
X-Fi!
Is this really the way I should be going when I look at getting a sound card? I will probably only get the OEM version, can anyone advise if this is the best option? If not what else would you reccomend? Not too expensive.
