| | #11 (permalink) |
| Win XP Pro / Win Vista Ultimate | Re: Need help finding correct driver or this one, same one, but from a different site Download Sigmatel HD Audio Driver 6.10.5405.0 x32/x64 Driver for Windows Vista |
| | #12 (permalink) |
| Vista 64bit | Re: Need help finding correct driver Says This is not the correct audio driver for this system... |
| | #13 (permalink) |
| Vista 64bit | Re: Need help finding correct driver I've tried to find the correct chipset drivers for my main board, but with no luck. I keep getting installation errors. "Error unknown", "You are not using Windows Vista", "Your computer is not the right model", to simply... "Error!" |
| | #14 (permalink) |
| Vista 64bit | Re: Need help finding correct driver I'd like to inform the vista community that i've wiped my drive. I currently dont' have an OS on that P.O.S. Sony Vaio. My recovery info. is on a floppy disk. My PC doesnt come with a floppy drive, so i was forced to go buy a $40 floppy external drive at best buy today. Brung it home, didnt wanna boot from it. I couldnt access it at all. Even tho its enabled in BIOS. I give up. Microsoft can kiss my ass. |
| problem getting correct realtek driver for toshiba laptop | Vista General | |||
| dxdiag not showing the correct video driver version. | Vista hardware & devices | |||
| finding correct cd disk's to use | Vista General | |||
| Finding graphics driver | Vista file management | |||
| Not correct driver message | Vista General | |||
