| vista | i have no sound i had sound day before yesterday on my pc i switched it on today and i have no sound the only time i have sound is when i put the pc to the hi-fi via the aux. any idea please thanks ive got vista 32 i think and its a real tech hd sound card |
| VISTA HOME PREMIUM X64/ 7 x64 / 7x86 | Re: i have no sound To check your playback devices: Click Start, type sound in the search box , then select Sound in the results listing. Right click a device and select the option to Configure and then Test each device, when you're finished, ok the dialogue box . Click Show Disconnected Devices to see what's listed there. To Check Volume Settings: Click Start>Control Panel>Hardware and Sound>Adjust System Volume Drag slider up or down for more or less volume. Click mute button underneath slider to see if it's muted. Hope this helps SIW2 |
| vista | Re: i have no sound hi i have tried this and it all works perfect when i run the pc through the aux on the hifi as soon as i want to play the sound through the pc it doesnt work. but the equalizers go up when i play some thing. ive uninstalled it a re booted the machine still not working |
| Vista 64 ultimate, Windows XP 32 Professional, Windows XP 64 Professional | Re: i have no sound hi i have tried this and it all works perfect when i run the pc through the aux on the hifi as soon as i want to play the sound through the pc it doesnt work. but the equalizers go up when i play some thing. ive uninstalled it a re booted the machine still not working ![]() when you are trying to play the sound through your computer where should the sound be coming out, ie have you external speakers attached to your computer and if you do, do they have their own independent power supply ie a plug to the household power electricity? Best and Warm Regards Adrian Wainer |
| vista | Re: i have no sound hi the sound should come out the monitor and its a pc im using |
| | #6 (permalink) |
| VISTA HOME PREMIUM X64/ 7 x64 / 7x86 | Re: i have no sound Hi, I assume you use a minijack lead from the light green output socket on the back of your pc to the back of your monitor. Try using the same lead and socket into your hi-fi to check they work. SIW2 |
| | #7 (permalink) |
| Vista 64 ultimate, Windows XP 32 Professional, Windows XP 64 Professional | Re: i have no sound Best and Warm Regards Adrian Wainer |
| | #8 (permalink) |
| VISTA HOME PREMIUM X64/ 7 x64 / 7x86 | Re: i have no sound Exactly, it would obviously mean the sound signal was coming out of the pc fine and the output socket and the lead are fine . The problem would be further down the line e.g. connector on the monitor , or inside the monitor itself. SIW2 |
| distorted sound in vista/createiv x-fi titanium sound card | Sound & Audio | |||
No sound when playing music or video, but internet sound works fine | Sound & Audio | |||
| Setting per Application Sound Output, or Per Sound Type Outputs... | Vista General | |||
| My Creative Sound Blaster X-FI Sound Card Works Now with Creative's RC1 Device Driver's! I Have Sound! | Vista General | |||
| Vista x64 RC2 - Sound Card/Amplifier - DTS Test Sound (Audigy 2 ZS SPDIF) | Vista General | |||
