Realtek ALC888S vs SB Live 24-bit/Audigy
DesoShade
Junior Member
Well I just Upgraded mobo and processor and after much much much hassel, managed to get everytrhing working. For some reason, this new mobo wouldn't allow an install of an older version of XP, only new versions with sp2. My legit copy was an older version and wouldn't install right, but that's not the topic here.
My new mobo comes with integrated Realtek ALC888S sound. 7.1 High Def with an hdmi output. I believe it's 24-bit sound and the specs on it look decent. I also have a SB Live! 24-bit card I've been using prior to new mobo.
Question is, how do the two compare? Am I better off sticking to my SB Live! 24-bit card, or trying out the new Realtek?
SB = 5.1, RT= 7.1
SB = 24-bit, RT = 24-bit too?
SB = no hdmi, RT = hdmi
SB has eax support. does RT? RT is High Def, is SB?
I'm confused. Which is better? SB or the integrated RT? :confused:
Realtek doesn't support EAX so if you have games that can use EAX use the SB.
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    7200 rpm
    Western Digital 160 GB IDE
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
Yeah I play games. :) Hey who doesn't? Hey, I'm wondering..... probably not, but do you think I'd be able to install... (ta dum) BOTH? Use the onboard and SB both? Switch between the two? I dual boot my machine with vista 64 and xp i386 and the SB card works suck for for vista. As one user in here put it, there's no EQ in vista, but the Realtek has full support... and an EQ. Think I could install both without conflicts? Without having to disable one of the other? Guess I could at least try... right?
Hi DesoShade. Please do give it a try. Please provide your findings, as I've done sort of what you inquired about, but with a X-FI in..........XP. ;)
Did have to choose between the two in Audio Control Panel.
Actually, you know what I figured? I probably COULD install both cards and configure Vista to run Realtek and XP to use the SB Live 24-bit, BUT, when I switched operating systems I would have to unplug the connections in the back. Say I'm using XP and Soundblaster, if I switch to Vista and Realtek, I would have to reach behind my computer, disconnect speakers from the SB and plug them into the Realteck. That would be a paaaain. Hmmmm. So basically, I have to choose one. Realteck or SB.
I'll probalby stick with SB. Probably better than the onboard anyway. Sure I'm missing out on the 7.1 surround, but my speakers are only 5.1 anyway. lol Graphic EQ, I can just use the jukebox EQ. HDMI output... I'll probably never use that anyway.
Sounds as if you have come to conclusion. I have latest Realtek use via Digital Out to 7.1 AVR on Vista and am quite impressed with Quality. X-FI similarly connected is very impressive with XP, but can do the switching that you mentioned for Realtek out to a Creative 7.1 Speaker Set and that provides a very nice Surround Sound. :)
digitall2 good reason that both sound good, when using the digital connection on the card (doesn't matter whether it is onboard or a card), the speakers (or whatever you connected to) are doing the decoding, not the card. For the most part the digital connection all comes down to how good the DAC is on the other end.
There is a very long thread (more than one actually) over at guru3d regarding the Auzentech Prelude, and the general consensus it that unless you are connecting to a reasonably high end amp/receiver, you would be better connecting the speakers using the analogue connections as in most cases the DAC on the card is better than the one in the speakers.
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Acer P221w and Acer 1916w
    1680x1050 and 1440x900
    Antec Earthwatts 500W
    Antec Sonata III
    Logitech Wave
    Logitech G5 v2
I'm still using the Realtek and it doesn't sound all that bad. At some point, I may upgrade to an xfi, but the realtek is doing quite well with vista.
