| vista home premium 32bit | duh...and help!!! Hi. I've had a Logitech headset for a year now, has worked great, but this morning while dealing with a capacity problem I started removing programs I didn't think i needed, and I think I must have removed the logitech software that came with this headset because I can no longer hear anything in my headset. Now I can't find the disc. How do i fix this. If it isn't already apparent, I know zilch about technology and tend to just plug things in, install discs, click yes when asked, and hope for the best. anyone? |
| Vista Ultimate 32 | Re: duh...and help!!! Try seatching for drivers on the internet google is our freind |
| Windows Vista™ Ultimate | Re: duh...and help!!! Hi. I've had a Logitech headset for a year now, has worked great, but this morning while dealing with a capacity problem I started removing programs I didn't think i needed, and I think I must have removed the logitech software that came with this headset because I can no longer hear anything in my headset. Now I can't find the disc. How do i fix this. If it isn't already apparent, I know zilch about technology and tend to just plug things in, install discs, click yes when asked, and hope for the best. anyone? ![]() Hi Larry, You can download the logitec headset software you need from here ![]() http://www.logitech.com/index.cfm/su...ads/downloads/ Steven |
| vista home premium 32bit | Re: duh...and help!!! thanks, you guys are awesome. I googled something that may or may not have fixed it (it's fixed, though I was mucking about with defaults that weren't set to logitech any more) but I will save that link in case I delve into areas beyond my capability once more. |
