Vista - Different Vol Sound Same New Computer?
Old 09-26-2008   #1 (permalink)
Vista Home Premium x64
I purchased 2 new computers, Dell Inspiron 530, with integrated RealTek Hi Definition Audio. On one computer the sound is louder than the other from the get go.
I haven't modified anything, and am wondering if this is due to something faulty or is there something I can repair/check?
They both have the same driver, 6.0.1.5548
Any suggestions? Thank you!
Old 09-26-2008   #2 (permalink)
Vista Ultimate x86-32 SP1 dual boot with Windows XP SP3
Re: Different Vol Sound Same New Computer?
Hi! Amelia! Welcome to Vista Forums!
Try this: Right click the volume icon in the task bar n click on playback devices.
Next, Select your default sound output [it'll have a green check mark] and click on Properties at the bottom of the window.
Now, head over to the Enhancements tab n look at whether or not Loudness Equalization is checked.
If it is checked, try un-checking it and then click OK and close all Sounds windows and see whether the loudness has disappeared.
Old 09-26-2008   #3 (permalink)
Hi Dragor, thank you for the quick response!
With both computers, it was unchecked when I went to go look.
Should I do something else?
Old 09-27-2008   #4 (permalink)
Quote  Quote: Originally Posted by ameliajune View Post
Hmmm... does your problem still exist after you check it on the affected computer?
Look, ideally, it is supposed to be a great option which boosts audio when a movie has very low audio and also vice versa i.e. lower volume if a movie has too high a volume.
But this thing has its quirks, which I notice when I turn on my Stereo speakers. The volume shoots up no apparent reason sometimes.
Having said that, I leave it on if I am using my headphones cause it really does a good job in this case.
Hope this helps.
No Sound Comcast HD Box, To computer SPDIF Sound & Audio
I cannot hear sound from my computer .NET General
Record Sound from computer.HELP. Sound & Audio
Getting my computer to make a sound every second Vista General
computer doesn't play sound Vista music pictures video
