No sound with vista! =(
macolas
Hi.. well yeah im another one of the victims that has no sound with vista... :( and belive me i spent almost 5 hours trying to fix it, i tried allmost everything that i could found on the internet. nothing workt. :(
but the thing is that i have all the drivers software on a cd that i got with the computer, but when i put the cd in.. it says "Error code : 2 (2H) the system cannot find the file specified".
so my question is. what am i to do? how can i start the cd.
please help
Hello Macolas, and welcome to the forums,:party:
Need a bit more info to enable anyone to help can you post your system specs,
also the error you are posting could be related to a smudged/scratched CD.
what I would also suggest is that you check your system manufacturers website for the latest sound drivers (especially for x64), the driver situation is still very fluid and you will quite often find that the disks supplied are out of date before the system is even shipped :(
    2 x 1920x1080 @50Hz
    Asus M5A78L-M USB3
    32GB [4x8GB] DDR3 1600 MHz
    Asus nVidia GTX750TI-OC-2GD5 (2GB DDR5)
    Samsung 32" TV
    Internal
    Crucial CT256MX100SSD1 256GB SSD,
    Seagate ST2000DM001-1CH1 2TB,
    External (USB3)
    Seagate Backup+ Hub BK SCSI Disk 8TB
    2.5/3.5 Hot Swap Cradle, USB3 + eSata (client HDDs)
    NAS 4TB
    68 MB Down 18.5 MB Up
Have you tried downloading the drivers from the manufactures website.
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    7200 rpm
    Western Digital 160 GB IDE
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
SIW is my diagnostics program of choice
SIW | System Information for Windows by Gabriel Topala
may want to give this a try :D
in the meantime will try to get further info on your system.
Update
Ok your motherboard comes back as a Jetway HA03 Ultra (AMD 790X), have tried to get further info but Jetway site appears down at present will post back if/when can get further info
    2 x 1920x1080 @50Hz
    Asus M5A78L-M USB3
    Samsung 32" TV
    Internal
    External (USB3)
    NAS 4TB
Update
man your rock! i mean it ;D your the man! :D:D
FINALLY I FIX IT!!!!!!!!!!!!!!!!! YEEEEEEEEEEEEEEEEEEEEEEEEEEEEES!!!!
i downloaded Driver Genius Pro 2008. it found my drivers fast downloaded it fast and BOOM i got sound ><!!!!!! soo damn happy now :):) thanks for everything :)
great to hear that :D :party:
    2 x 1920x1080 @50Hz
    Asus M5A78L-M USB3
    Samsung 32" TV
    Internal
    External (USB3)
    NAS 4TB
Kudos to you. I was in the same boat. I downloaded Driver Genius, Driver Detective, but they all wanted me to buy it. I'm from Canada and I'm not exactly keen on doling out money, because by the time it gets here there are so many taxes on it. I'm on food stamps for a month.
Anyways I downloaded A trial version of RadarSync. It's rated the last of those three I just mentioned. I did a scan and it found the update for my sound driver, along with a few others, I clicked on install and it installed it for me.
:D
I didn't know where to post because this topic is polyposted everywhere. Like Macolas, i've been searching the web and trying all day to fix the audio on my pc bought today.
Thing is: At the shop this afternoon my pc was hooked up with HDMI, and everything seemed to work fine. At home however i got no sound from my headphones, speakers (connected with headphone plug) plugged in the front or Dell stereo speaker system with the single green plug connected on the back.
But i can't really find a manufacturer for the onboard sound card. I read something about headphone possibilities appearing after driver software updates. Another complicati:cry:n: I have no internet either since there doesn't seem to be a x64 firmware for my siemens gigaset usb adapter 108. S
Sorry to bore yall with the same lame question again. Hope someone can find the time to help me out. Sebastian
Motherboard= Abit AN78gs, Antec 300 casing.
hello thelordofthethings, welcome to the forums :party:
just reading about the HDMI setup in the shop,
right click on the sound icon in the tray and select output devices
in the dialogue that appears if you have two options, Speakers and digital, check that the speakers (or at least not the digital), is set as default, It may be if they were set up for hdmi then the digital output is selected and that would not work with the normal ports.
I think it's a realtek sound chip on this board but can't find any definitive info
    2 x 1920x1080 @50Hz
    Asus M5A78L-M USB3
    Samsung 32" TV
    Internal
    External (USB3)
    NAS 4TB
You're right, it was a realtek driver, i called to the shop the next day and he told me he'd only installed the hd exit driver. So i just had to insert the disc that came with the motherboard(DUHhhh) Anyways tnx for reply.
Hi glad to hear you've fixed it :D
    2 x 1920x1080 @50Hz
    Asus M5A78L-M USB3
    Samsung 32" TV
    Internal
    External (USB3)
    NAS 4TB
I have lost sound on my computer.I had this when I first got my windows vista ,home premium, operating on 32 bits. A computer shop ,after few clicks ,the sound was there.
How do I get the sound back. Please help
Make and model of your pc please also is your sound listed in the device manager under sound,video and controllers.
    Asus M2N68-LA
    On board RealTek
    Acer X163W LCD
    1366x768
    7200 rpm
    Dynex 400w
    Nothin Special
    Stock
    Comcrap 10mb cable
    Asus M2N68-LA
    On board RealTek
    Acer X163W LCD
    1366x768
    7200 rpm
    Dynex 400w
    Nothin Special
    Stock
    Comcrap 10mb cable
