| Vista Ultimate x32bit | Microphone Workus! Shoopus My Woopus! Ever since I got Vista, my computer has been a piece of crap. I swear, ok now here's the problem. My microphone dont work. I have the latest drivers soudn works, just microphone doesnt work. Help plz. |
| Windows 7 RC | Re: Microphone Workus! Shoopus My Woopus! Try downloading, running and posting the results from our Sysinfo tool. It will help the group provide you with assistance: http://www.vistax64.com/software-too...info-tool.html |
| Windows 7 Ultimate 32 bit Beta, Vista Ultimate x86 | Re: Microphone Workus! Shoopus My Woopus! Are you using an Audio Card or On-Board Audio. Make sure the microphone is plugged into the active audio system. If you are plugging into the front microphone connection, try using the connection on the card or motherboard. Make sure the Microphone is switched on in the Audio control panel. |
| Vista Ultimate x32bit | Re: Microphone Workus! Shoopus My Woopus! It was an Audio Card, it was plugged in and I never noticed I had a built in Intel Audio one that worked PERFECTLY. Fixed it. |
| Windows 7 Ultimate 32 bit Beta, Vista Ultimate x86 | Re: Microphone Workus! Shoopus My Woopus! Vista Dan, You the Man. Glad you've solved your problem. |
| Help With Microphone Please | Sound & Audio | |||
| microphone | Sound & Audio | |||
| microphone | Vista hardware & devices | |||
| Why cannot I use my microphone? | Vista General | |||
| Microphone | Vista hardware & devices | |||
