| Vist Ultimate x64 | Sound Stuttering It seems like this problem has been famous since 2007... So I just bought a new laptop, HP Pavillion nv9925nr. Specs are AMD Turion64 x2. ram is at 4gigs ddr2 667mhz. Nvidia Geforice 7150m and a Conexant High Definition Audio card (all this is onboard... dur) Anyway, my problem is that every minute or so the sound stutters, all my drivers are updated, got all the windows update thrown in there, and it still does the stutter thing every minute or so. Is there any solution to this problem to save my sanity? Thanks : D |
| Windows 7 RC x64 Vista HP x86 | Re: Sound Stuttering Hi TemperFire, welcome to the vista forums No cure yet as far as I am Aware of... Just the normal workaround Right click the speaker icon in the tray select Playback Devices select your default output and on the enhancements tab Disable all enhancements. Hopefully that should do the trick but if not try disabling all enhancements in the playback application (media player) hope this helps |
| Vist Ultimate x64 | Re: Sound Stuttering Hi TemperFire, welcome to the vista forums No cure yet as far as I am Aware of... Just the normal workaround Right click the speaker icon in the tray select Playback Devices select your default output and on the enhancements tab Disable all enhancements. Hopefully that should do the trick but if not try disabling all enhancements in the playback application (media player) hope this helps |
| Windows 7 RC x64 Vista HP x86 | Re: Sound Stuttering Hi TemperFire, good to hear you're up and running |
| sound keeps stuttering towards the end of each track | Sound & Audio | |||
| stuttering sound | Media Center | |||
| Any Fix for Sound Stuttering in a WinXP VM running under Vista? | Virtual PC | |||
| Stuttering TV picture & sound | Vista General | |||
| Sound Stuttering and Other Audio Issues | Sound & Audio | |||
