Host OpenAL (ADI)
kzone
Does anyone have any idea what this is? Just appeared in my installed programs, something to do with Creative, but i use onboard soundmax, which is good enough for me and don't have a soundblaster installed. Don't even know what installed it...
vista 64prem
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    7200 rpm
    Western Digital 160 GB IDE
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
Its part of creative audio card here is a link.
Sound Blaster Gaming: Introduction to OpenAL
Yes and no. The Host OpenAL is a software extension that allows non-hardware based sound cards (which would be everything but the Audigy 1/2/4 and X-Fi line (minus the Xtreme Audio)) to use the OpenAL API. Much more info here,
OpenAL - OpenAL® and Windows Vista™
The software extensions were added to OpenAL just over a year ago,
Changes and Bugfixes
* Added new enumeration extension (ALC_ENUMERATE_ALL_EXT) to use AL on any soundcard / audio endpoint
* "Generic Hardware" device only appears in the enumeration string if it can be used
* Fixed alcGetIntegerv's requirement for an active context
* Fixed alcCaptureOpenDevice so that it returns 'NULL' if the capture device fails to open
* Fixed software reverb bugs (Reflection Delay and Air Absorption HF)
Downloads
It seems that it just took ADI (no idea if or when RealTek added it, but assume they have) a while to integrate it into their drivers (and can be installed manually from the link above).
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Acer P221w and Acer 1916w
    1680x1050 and 1440x900
    Antec Earthwatts 500W
    Antec Sonata III
    Logitech Wave
    Logitech G5 v2
Yes and no. The Host OpenAL is a software extension that allows non-hardware based (?) sound cards (which would be everything but the Audigy 1/2/4 and X-Fi line (minus the Xtreme Audio)) to use the OpenAL API. [...]
Non-hardware based?... Virtual devices?
It's just the software needed for to use the OpenAL API, you may consider it analog to OpenGL but for Audio. Under Vista, is the only API that can actually use your Hardware Sound acceleration directly and EAX for Creative capable soundcards.
Even Host based Creative cards (non-DSP cards like CA0106 Audigy SE and X-Fi Xtreme Audio) can use the API even if only for positional audio without EAX.
  • Other Info
    Windows 7 is love~~
I had this "Host OpenAL" on My Windows 7 machine which does not use a Creative sound Card. I have a SoundMAX software utilty for my sound card.
I removed "Host OpenAL" and had no bad effects.
This "Host OpenAL" only arrived after installing a 3rd party gadget..?
