| vista home premium 64bit | realtek HD audio manager couple of problems seem to be occuring with this programme. firstly the front mic port is highlighted pink even when no mic is connected. is this normal? mic and headphones work fine but every now and then. in particular if i have speakers switched on it will pop up saying i have either connected or disconnected a device. can this be resolved? finally, i'm guessing i should keep my drivers up to date. is there anyway i can check if it is the latest version and if not where do i go to get an update? motherboard website or realtek. thanks in advance |
| Vista Ultimate x64 | Re: realtek HD audio manager Easiest place for the drivers, http://www.vistax64.com/sound-audio/...er-update.html You don't list your motherboard, but I would assume you will need the HD Codec driver and not the AC97 one. As for you other question you'll have to wait for someone that uses their Realtek onboard sound. |
| vista home premium 64bit | Re: realtek HD audio manager thanks stromy. any idea about the highlighted front port? |
| vista home premium 32 bit | Re: realtek HD audio manager how do you re-install the realtek hd audio to play again if it got disabled? |
| Realtek HD Audio Manager | Sound & Audio | |||
| Realtek hd audio manager | Sound & Audio | |||
| Realtek HD Audio Manager | Vista music pictures video | |||
| My RealTek Audio Manager | Vista General | |||
