| Welcome to Windows Vista Forums. Our forum is dedicated to helping you find solutions with any problems, errors or issues you are experiencing with Windows Vista. The Vista forum also covers news and updates and has an extensive Vista tutorial section that covers a wide range of tips and tricks. |
| | LinkBack | Thread Tools | Display Modes |
| Newbie | No sound at all in Vista - need help. hey, y'all - just installed Vista HP 64 bit and it went pretty good, for the most part. I am dual booting w/XP Pro 32 bit, on seperate hard drives. I'm pretty impressed so far. I do have one major problem - no sound at all. Here's my hardware setup: asus p5q pro, Intel c2d e8400, saphire radeon 4850, auzentech x-fi prelude, logitech z-5500, seagate 320gb sata(XP Pro), seagate 640gb sata(vista). soundcard & spkrs. work great in XP. I went to auzen website & d/l latest drivers, drilled down thru all the vista options & menus I could find, checked device mngr., and still no luck. Anybody got any ideas ? |
| The Contemplator ![]() ![]() ![]() Join Date: Mar 2008 Vista Home Premium 32-bit & Vista Ultimate 64-bit both Service Pack 2 W7 Ultimate RC 7229 32 & 64 | Re: No sound at all in Vista - need help. Hi wilburdee and welcome to Vista Forums ![]() I have had a look on the website: Auzentech, Inc. Sound Cards. Audio You Can Believe In. World First soundcards for Music, HTPC, and Gaming., and unfortunately, whilst Vista is mentioned, there is no explicit mention of Vista 64-bit. |
| Newbie | Re: No sound at all in Vista - need help. Dwarf - thanks for the reply, I was thinking the same thing. Driver supports Vista, but not x64. I thought I had heard that other people had used it in x64 but maybe not. What would my other sound options be - uninstalling the Auzen and going back to mobo sound? |
| Member | Re: No sound at all in Vista - need help. Try enabling the onboard sound card and see if Vista picks it up or windows update or check the mobo website if there is 64bit support for your onboard sound card. If you want to buy a sound card then from my experience creative sound cards should be good. |
| Member ![]() | Re: No sound at all in Vista - need help. Find just about everything you need to know about that sound card here, Auzentech Prelude Discussion Thread - Guru3D.com Forums 107 page thread only about it. And yes the card works with X64. |
| | #6 (permalink) |
| Newbie | Re: No sound at all in Vista - need help. Thanks for the reply and link Stormy, I'll check it out. |
| | #7 (permalink) |
| Newbie | Re: No sound at all in Vista - need help. I have the same problem - try to update the Auzentech drivers which seems to work, but the volume mixer icon indicates there is no audio apparatus installed, even though it mentions the Auzentech card. It also shows up as working in the System Manager and Sounds tab - anyone any idea what could have gone wrong (and yes, I did reboot after the install, so that can't be the problem). For the record, before the update the card worked perfectly... |
| | #8 (permalink) |
| Newbie | Re: No sound at all in Vista - need help. And to make things even more complicated I DID get sound when the card tested for virtual surround - but apparently it doesn't show up in any other application. Plus, the volume knob on every window of the Auzentech console software is grayed out and inacessible... |
| Display Modes | |
| Sound Problems - Vent, Xfire, Steam voice - no sound | ZebraS | Vista hardware & devices | 2 | 01-02-2008 07:38 PM |
| Low sound from speakers and no windows sound on new vista | Karen | Vista hardware & devices | 2 | 03-24-2007 07:56 AM |
| Laptop Sound card + Vista - NO SPEAKERS!! + NO SOUND | FriarTuck91 | Vista hardware & devices | 0 | 11-04-2006 06:39 AM |
| My Creative Sound Blaster X-FI Sound Card Works Now with Creative's RC1 Device Driver's! I Have Sound! | Kevin John Panzke | Vista General | 1 | 10-14-2006 05:36 AM |
| Vista x64 RC2 - Sound Card/Amplifier - DTS Test Sound (Audigy 2 ZS SPDIF) | Terje Alexander Barth | Vista General | 0 | 10-14-2006 05:13 AM |
