Vista - No Analog Realtek
Old 12-25-2008   #11 (permalink)
Vista Ultimatex64 Windows 7 build 7100
Re: No Analog Realtek
Go here get driver sweeper;
Guru3D - Driver Sweeper
Install it, read how to use it under the help tab. You have to run it as administrator.
Start, Control Panel, Programs, Uninstall a program,
Uninstall your audio drivers. Anything labled Realtek
Do not restart when requested but use Driversweeper to check that everything is uninstalled.
Restart your computer vista will detect your hardware and install drivers. You may have to accept a UAC prompt.
You will not have the Realtek software this is unimportant.
Try your sound.
You may have to set it up by right clicking on the speaker symbol and selecting Playback devices.
Should look like the attached.
I hope this helps
Pooch
Old 12-25-2008   #12 (permalink)
attached
Old 12-26-2008   #13 (permalink)
Windows Vista Ultimate x64
You mean this will give me a device labeled High Definition Audio Device?
It produces the same noise as realtek, I had it at first when I installed vista.
I'll try driver sweeper anyway
Old 12-26-2008   #14 (permalink)
Quote  Quote: Originally Posted by DieForDethklok View Post
I mean. That it you do it like I say it will remove the old driver, then any rest bits of driver will be removed as well. Finally it will install the same driver that I am using and that I know works with this device.
A clean install will help me to decide if it is your hardware that is causing the problem or not.
Pooch
Old 12-26-2008   #15 (permalink)
Well it worked just fine under XP SP2.
Old 12-26-2008   #16 (permalink)
This device also works fine under Vista. I am listening to it right now
Something has gone wrong with yours and I am trying to help!!
Old 12-26-2008   #17 (permalink)
I'm thankfull for your help
I have retrieved a full package and documentation that came with a computer (the computer is not mine, I'm was just asked and begged to get it running), and I have dicovered the following:
There is an aditional SPDIF/SV/HDMI output card that was not installed inside, and is labeled by mobo manufacturer, with the same mobo model (ASUS M2N-VM HDMI). I'll try installing that, maybe this would help.
Yeah, I know it works fine under vista, I use it on my own PC
Old 12-26-2008   #18 (permalink)
Vista Ultimate Service Pack 1 x86_64
Quote  Quote: Originally Posted by Es0ter1c View Post
My GIGABYTE GA-M750SLI-DS4 motherboard (GIGABYTE - Product - Motherboard - Main Page with a built in HD audio board made by Realtek. According to the mfg website it uses the Realtek ALC889A codec.
My system setup is as follows:
AMD Phenom 9850 Quad Core Black processor.
2x 2GB RAM (utilizing 2 of the 4 available slots).
Windows Vista Home Premium 32 bit OS.
I am running the F5 version of the BIOS, as the F6 is glitchy and caused me CMOS problems initially. I intend to wait for F7 to see how that fares.
Here is my issue: I have researched in detail and have come down to this problem.
In the Realtek Device Chooser software screen the only option available to me is 'Realtek Digital Output'. The 'speakers' option and the 'NVIDIA HDMI Output' options are greyed out and completely unchangeable. I cannot modify or change anything listed in those options. As I do not own any HD audio equipment (nor do I intend on purchasing any in the near future), I cannot verify whether or not the HD audio features truly function. All of the analog jacks are completely greyed out, I show four jacks on the list but none of them display as usable, again completely greyed out. I own a set of Bose Companion III speakers, consisting of two satellite speakers for L and R sound and a subwoofer. All 3 of these are routed to a standard analog mini jack that I used on another machine with the standard green audio out port, and they function just fine. So I know they are not the problem either.
I CAN, however get a Logitech USB Headset to play sound. It functions through the Realtek software as it would be predicted. No issues there. However, it is sad when I cannot have even basic music playing in the room unless I am tethered to my machine. While it does not render my machine unusable, it is a considerable drawback.
Essentially I am able to get NO EXTERNAL AUDIO from this device. I am otherwise happy and impressed with the quality of the hardware on the motherboard but this is terribly depressing, as it seems my only option to get usable external audio is to sacrifice my SLI capability by plugging an audio card into my one remaining PCI slot.
I have downloaded various versions of both Realtek and GIGABYTE software/drivers in order to attempt to resolve this issue. I have removed the audio drivers completely and reinstalled with the most current on the Realtek site also, to no avail. I have researched various google results, including but not limited to forums, manufacturers websites and microsoft fixes, with no change. I am not an 'expert' at this type of troubleshooting but from what I can tell this seems to be a software related issue and not a hardware one. I am fully prepared to be wrong if it corrects my issue. I spent a pretty penny on this machine and would like to get it audible ASAP. If anyone knows of any ongoing issues I'd love to be informed, please let me know if there's any hope or whether I should just be satisfied with a mediocre graphical framerate and go buy the 40 dollar sound card.
Thanks!
Same problem with the front panel. http://www.vistax64.com/sound-audio/...tml#post913702
Instead the rear panel works fine..
Old 12-27-2008   #19 (permalink)
Quote  Quote: Originally Posted by DarkRadeon View Post
Hi DarkRadeon,
Check that the front panel is connected properly to the MB
Make sure that the audio jumpers are set correctly
Details are in the MB manual if you don't have this you can download it from the manufacturers website.
I hope this helps
Pooch
Old 12-27-2008   #20 (permalink)
Quote  Quote: Originally Posted by pooch View Post
Hi DarkRadeon,
I hope this helps
Pooch
The front panel is connected to the MB and the jumpers are set correctly. Only with the new drivers since the R2.08 i got this problem.
Realtek HD Audio digital & analog outputs Vista hardware & devices
No analog sound from Realtek HD Audio Vista hardware & devices
No analog sound with Realtek HD Audio Vista General
Realtek problem with analog on-board.. Vista hardware & devices
