| | #21 (permalink) |
| Vista Ultimatex64 Windows 7 build 7100 | Re: No Analog Realtek Go to device manager, select your audio device, select the Driver tab and finally select Roll Back Driver. If this fails to work then you will have to use an application like driver sweeper to remove the old driver and then reinstall the last known working driver. Guru3D - Driver Sweeper Pooch |
| Realtek HD Audio digital & analog outputs | Vista hardware & devices | |||
| No analog sound from Realtek HD Audio | Vista hardware & devices | |||
| No analog sound with Realtek HD Audio | Vista General | |||
| Realtek problem with analog on-board.. | Vista hardware & devices | |||
