| Vista Ultuimate 32 | Can't Play CD's I have Windows Vista Ultimate and it will not let me play a CD for more than half a minute. I get the following message... this is my second post and hopefully the message (.jpg) is visible. Harold |
| Vista Ultimatex64 Windows 7 build 7100 | Re: Can't Play CD's Hi Harold, This is a media player thing, try using a different player ie Winamp Pooch |
| Vista Ultuimate 32 | Re: Can't Play CD's Thanks Pooch. I downloaded it as you suggested and now all i get is the first few words of the first song and it repeats itself over and over. Back to the drawing board for me. But thanks, Harold |
| Vista Ultimatex64 Windows 7 build 7100 | Re: Can't Play CD's Ok, then it can not be to many things, Is the cd clean? yes, no. Do you have another drive to try? does it now work? Have you have burnt the cd yourself? Check the cables on the Writer Then try burning it again at a slower speed. Still doesn't work change the RW cd's Or your drive may be defect. |
| Vista Ultuimate 32 | Re: Can't Play CD's I've tried everything Pooch. Thanks for trying to help but i am going back to WinXP |
| | #6 (permalink) |
| Vista Ultuimate 32 | Re: Can't Play CD's Thanks for the help Pooch but as a gamer I am fed up with reinventing the wheel. I am putting WinXP on this computer of mine within the next couple of days. Got too many other things to do beside trying to make something work in Vista. Thanks again, Harold |
| Can't play CD's and DVD's | Vista music pictures video | |||
| help cd's wont play | Vista hardware & devices | |||
| Now I can't play CD's.... | Vista General | |||
| Cannot play audio CD's | Vista General | |||
| Cannot play audio CD's | Vista hardware & devices | |||
