Vista - audio red cross - Conexant HD audio
Old 12-18-2008   #1 (permalink)
Vista Home Basic 32 bit
"no audi device installed, in volume mixer"
hi all,
Im trying to help a friend fix their sound on their HP Compaq Presario F500 (2EA) Laptop. They have the annoying red cross over the audio icon on the bottom right hand corner of the screen (No Volume Mixer).
I have tried numerous things like:-
- Completely uninstalled the (Conexant High Definition) drivers in device manager, restarted and let Vista install them again.
- Downloaded latest drivers from RealTek,, and also HP
- Unfortunately their are no system restore points before the problem happened.
I have a sneaking suspision that either Windows Update installed something that is clashing with this problem or I herd that Itunes may have somethign to do with it (Which was installed near the time) .
Please help :-)
compaq laptop Presario f500 - AMD Mobile Sempron
Windows Vista Home 32 bit
1.8Gig
1G ram
6100 Go Geforce (Up to date drivers)
Conexant High Definition Audio seems to be working ok (with the green tick in playback devices) (SPDIF Interface)
Ive searched high and low and tried to install numerours patches etc.. but unsuccessful.
Thanks for any help,
Will
Old 12-18-2008   #2 (permalink)
Vista Ultimatex64 Windows 7 build 7100
Re: audio red cross - Conexant HD audio
Hi Will,
Welcome to the forum.
Red cross, this happens when no device is selected
Have a look at the attached picture, this is how your device list should look
still no good try disabling all unused devices, by right click
Make sure there is a tick in show disconnected devices
I hope this works
Old 12-18-2008   #3 (permalink)
hey Pooch,
I seem to have two available in the playback devices:-
Internal Speaker/Headphonrd (Conexant HD Audio) and
SPDIF Interface (ticked - working) Conexant HD Audio
Both show disabled and disconnected devices are ticked
Will
Old 12-18-2008   #4 (permalink)
Quote  Quote: Originally Posted by aceooo2 View Post
hey Pooch,
Will
Right click on Internal Speaker/Headphonrd select enable, Left click on Internal Speaker/Headphonrd and select Set Default (under the device Icons)
Left click on Internal Speaker/Headphonrd and select Configure (to the left of Set Default) follow the simple wizard
Check your sound
Reboot might be necessary
Pooch
Old 12-18-2008   #5 (permalink)
They both seem to be enabled,, as the only option I get for both of them is disable.
Plus set default and configure and shaded out : - s
Will
Old 12-18-2008   #6 (permalink)
Note Set Default and Configure are greyed out until a Device is selected Just follow my guide exactly as I have written it
Right click on SPIDF select disable,
Left click on Internal Speaker/Headphonrd and select Configure, follow the simple wizard
Check your sound
Pooch
Old 12-18-2008   #7 (permalink)
Yeah Im aware it has to be highlighted but it still does not disable.
Even when I go into properties and select disable in the drop down list next to device usage
Thanks for your patience
Will
Old 12-18-2008   #8 (permalink)
Ok Will
Go here;
Guru3D - Driver Sweeper
A program to uninstall drivers completely
Download, install and run Driversweeper
You will need to select sound drivers and deselect any other drivers
Reboot and install your sound drivers again
Hopefully this time it will work
If not, I am back Tomorrow
Old 12-26-2008   #9 (permalink)
Vista Home Basic
I have this probelm too!!
Someone please help me!!
Except when I click on my sound mixer icon, there is no devices to be selected.
It also happened to me after I used windows update. After it restarted the computer.
But like I said, when I click it, there are no devices to choose.
Old 12-26-2008   #10 (permalink)
Vista Ultimate 64bit SP2/
Right click in the sound mixer area and show disabled and hidden and see if anything shows up.
Conexant HD Audio not working Vista hardware & devices
Conexant HD audio problems Drivers
Conexant HD audio driver? Vista hardware & devices
Conexant AC-Link Audio FIX!!!!!!!!!!!!!!!! Vista hardware & devices
Conexant audio drivers Vista hardware & devices
