Vista - No sound
Old 12-26-2008   #1 (permalink)
Vista 32bit home basic
No sound
Hi
Earlier on today, i unplugged my speaker jack to put it into a laptop (didnt work), i then plugged it back into my PC and the sound didnt work. I also tried plugging in headphones (into the rear panel, the front panel has never worked for headphones), they also didnt work. I plugged my speakers into my ipod and they worked, so im guessing its to do with the computer. The speakers are definatly wired up correctly.
The speakers are labtec pulse 350
I have vista 32bit home edition and have never had any problems with these speakers before.
Thanks in advance :)
Old 12-26-2008   #2 (permalink)
Vista Home Basic
Re: No sound
I cant offer any help, but I can say I know how youre feeling! My laptop is doing the same thing.
On your taskbar does your volume icon have an X in a red circle?
Wonder if were having the same problem
Old 12-27-2008   #3 (permalink)
Re: No sound
hi
my volume bar is there (with no red cirlce or x), but it only has the volume for my digital output device, im assuming thats my sound card. Also, my computer says that the speakers arent plugged in, so prob different problem.
Isnt that red circle with a cross a sign for when the sound is muted btw?
Old 12-27-2008   #4 (permalink)
Vista Home Premium x64
Re: No sound
Quote  Quote: Originally Posted by Killeroo599 View Post
hi
hi killeroo, can you right click your volume icon for me, open the playback devices option, if you look in there and tell me what options you have, if you have a "speakers" option, can you select it and set as default device. this should solve the problem, ive also attached an image of what you need to do.
Old 12-27-2008   #5 (permalink)
Re: No sound
distorted sound in vista/createiv x-fi titanium sound card Sound & Audio
Solved No sound when playing music or video, but internet sound works fine Sound & Audio
Setting per Application Sound Output, or Per Sound Type Outputs... Vista General
My Creative Sound Blaster X-FI Sound Card Works Now with Creative's RC1 Device Driver's! I Have Sound! Vista General
Vista x64 RC2 - Sound Card/Amplifier - DTS Test Sound (Audigy 2 ZS SPDIF) Vista General
