Vista - Un-installed its own speakers?
Old 12-26-2008   #1 (permalink)
Vista Home Basic
Im not sure if I should put this under update probelms or what, but Im highly confused.
I downloaded the Malicious Software Removal Tool, thru Windows Update. (Not a pop up online)
After it was done with the update, it restarted my computer, and when it was done, I discovered that it had UN INTSALLED the speakers.
The new software hadnt even run yet, so I doubt it had anything to do with that.
When I click on the volume icon on my task bar, it says that there is "No Audio Output Device Installed"
WHAT IS GOING ON
All I have on this laptop (Toshiba, year old) for speakers are the ones BUILT into it. I was unaware a computer could delete its own speaker device....
Does anyone have idea WHAT the heck is going on?
Old 12-26-2008   #2 (permalink)
Vista Home Basic
Re: Un-installed its own speakers?
My Laptop is a Toshiba Satellite. A100
PSAA2E
Running Vista 32bit apperntly
Old 12-26-2008   #3 (permalink)
Vista Ultimate 64bit SP2/
Go into your device manager and see if there are any errors for anything.
Old 12-26-2008   #4 (permalink)
Old 12-26-2008   #5 (permalink)
Vista Home Basic
Im not sure if this is the right one I want but this is what it says
Old 12-26-2008   #6 (permalink)
I would download and install the drivers that I have linked for you and restart your computer after installing and see if you get any sound and see if your device shows in the sound manager.
Old 12-26-2008   #7 (permalink)
Vista Home Basic
ok awesome thanks, be back in a bit
Old 12-26-2008   #8 (permalink)
Vista Home Basic
Didnt do a darned thing. Installed everything, restarted, and when I go to the sound mixer thing, still says there are no devices installed, and no option to search for any
Old 12-26-2008   #9 (permalink)
Ok go into the device manger where you posted the screenshot and double click on Realtek High Def and try rolling back the drivers for it and if that doesn't work uninstall the device and install the drivers again and restart.
Old 12-26-2008   #10 (permalink)
Vista Home Basic
there is no option to roll back
but ill try un installing etc
I find it weird it says the device is working fine, but its not at all
Using External Speakers and Laptop Speakers Sound & Audio
external speakers not working/pc has internal speakers Sound & Audio
Last night I installed an update and now my speakers dont work Vista hardware & devices
USB speakers wiped out my built in speakers Vista hardware & devices
INstalled audio drivers but no sound from speakers Vista installation & setup
