Vista - No Sound
Old 12-31-2008   #1 (permalink)
Vista Ultimate 32bit
No Sound
Hello I have some problems with my Realtek AC97 Sound Driver:
I opened my PC and i saw there is a red cross on the sound icon in the taskbar
(taskbar.jpg) Then i opened Sound Control Panel and there was: No audio devices installed (soundcpanel2.jpg) (soundcpanel2.jpg). Then i opened Device manager there was no any device about audio here (devicemanager.jpg).
I installed Driver Agent And scanned for drivers. The Realtek AC97 driver was in the Disconnected Drivers List (driveragent.jpg).
What can i do?
Thanks,
Kasya
Old 12-31-2008   #2 (permalink)
Vista Ultimatex64 Windows 7 build 7100
Re: No Sound
Quote  Quote: Originally Posted by Kasya View Post
What can i do?
Thanks,
Kasya
Hello Kasya,
Goto Start, Control Panel, Programs, Uninstall a Program, if you have anything realtek uninstall it. Do a reboot if requested if on restart the drivers remain uninstalled or if you have nothing to uninstall read further
Go here;
Realtek
Download and install the vista driver
I hope this helps
Pooch
Old 01-01-2009   #3 (permalink)
Re: No Sound
Hello,
Thank you for your help but nothing changed. I removed from Programs And Features Realtek AC97. It wrote drivers uninstalled. I rebooted my pc. Then started installing Vista driver. It started telling me the driver isn't certified. I clicked install anyway. Then it said Driver installed and i rebooted my pc. But after reboot nothing changed. The red cross on audio icon in taskbar still exist. No Driver in Device Manager.
What can i do?
Kasya
Old 01-01-2009   #4 (permalink)
Vista Ultimate 64bit SP2/
Re: No Sound
What is the make and model of your PC.
Old 01-01-2009   #5 (permalink)
Vista Home Premium 64bit
Re: No Sound
It may be the onboard sound peripheral has not been turned on via the BIOS settings
Old 01-01-2009   #6 (permalink)
Windows Xp Pro SP2
Re: No Sound
What can i do?
Thanks,
Kasya
Goto Device Manager , CLick on View -> Show hidden device , send us the screenshot
Old 01-01-2009   #7 (permalink)
Re: No Sound
These Are the pics.
Old 01-01-2009   #8 (permalink)
Re: No Sound
Quote:
Clevo
It is turned on in BIOS
Quote:
mansrm81
Gigabyte GA-8IPE1000-G (very old model )
Old 01-01-2009   #9 (permalink)
Re: No Sound
Another possbility then is that if you were upgrading the driver...the first time you run the new driver install it actually un-installs the current driver then it when you install again that it installs fully.
Old 01-02-2009   #10 (permalink)
Re: No Sound
Here is the problem not only is the MB very old, but you are unlikely to get working vista drivers for your particular chip
Try here;
http://www.giga-byte.com/Support/Mot...ownloadFile.as px?FileType=Driver&FileID=817
These drivers are for your chip are also unsigned and may I believe install to Vista with a few warnings if you are lucky they may also work
Should they not install properly they will almost certainly extract to a temporary folder either on C:\ or under your user I don't know what it would be called so you will have to look for itand you should then be able to install them by clicking on the sound device in the device manager and pointing it to the driver in the temporary folder
distorted sound in vista/createiv x-fi titanium sound card Sound & Audio
Solved No sound when playing music or video, but internet sound works fine Sound & Audio
Setting per Application Sound Output, or Per Sound Type Outputs... Vista General
My Creative Sound Blaster X-FI Sound Card Works Now with Creative's RC1 Device Driver's! I Have Sound! Vista General
Vista x64 RC2 - Sound Card/Amplifier - DTS Test Sound (Audigy 2 ZS SPDIF) Vista General
