Vista - HDMI Sound Problem
Old 12-31-2008   #1 (permalink)
Vista Ultimate 32bit
HDMI Sound Problem
I built my own HTPC last summer:
Zalman Case
ECS A780 GM-a motherboard
4 GB RAM
1.3 TB storage
It has worked fine, both audio and video, for months with my 62" Mitsubishi DLP TV through the HDMI connection on the motherboard. I bought a new Mitsubishi 73" (WD-73735) and I cannot get the audio to work (video is great 1080p). I have tried everything, driver update, OS update and I have tried every setting in the sound area in control panel. It shows everything is right, no mute, driver OK, HDMI sound is the default even shows a sound bar jump when I move the slider up and down.
I moved the 62" TV into another room so I disconnected the HTPC from the new TV and reconnected on the 62" TV, everything works (audio and video), move it back and no audio .
It is obviously a problem between the ECS MB and the new TV. I know the new TV is HDMI 1.3 compliant but I assume it is also backward complient to all HDMI standards. All my other HDMI systems (cable, blu-ray, etc.) work on the new TV, just the HTPC has problems.
The video on the MB is ATI HD3200 and the audio is ITD, I updated both drivers to no avail.
Anyone have an idea why it doesn't work?
Thanks,
Clancy52
Old 01-01-2009   #2 (permalink)
Server 2008 R2 , Windows 7 6801 + 6936 x64,6801 6956 x32, Windows Home Premium Sp1 x64, Linux
Re: HDMI Sound Problem
what model # is your older 62 inch tv??
Old 01-01-2009   #3 (permalink)
Sorry for the delay, been doing family stuff. The 62" is a Mitsubishi WD-62627 built in 2006.
Old 01-01-2009   #4 (permalink)
Vista Ultimate x64 SP1
Hi Clancy52,
Unfortunately there seems to be an issue where ATI cards with HDMI outputs don't seem to work with all HDMI recievers/TV's. This issue has been discussed here - ATI 4850 does not recognize Yamaha receivers as HDMI audio devices-DVI instead? - Page 2 - Rage3D Discussion Area. You'll have to read through it though.
Supposed workaround discussed in the thread here - EDID Override Thread - AVS Forum
Also, in addition to updating your video card drivers, I would also advise you to download Realtek's HDMI drivers as well. Once you check the "accept to the above" box, click next, then click "High Definition Audio Codecs (software)", then look for "ATI HDMI Audio Device" and choose a site to download.
Good luck
Old 01-01-2009   #5 (permalink)
good fix sygnus....
i was thinking it was an HDMI cable or ATI not supporting 1.3a...
yours make's sense....
i agree with sygnus look into the hdmi drivers also...
Old 01-01-2009   #6 (permalink)
Quote  Quote: Originally Posted by darkassain View Post
good fix sygnus....
Guess my hanging out in various forums comes in handy
Old 01-01-2009   #7 (permalink)
I will try this tonight. It sounds like it makes sense to me. IOU1......
I will let you know.
Old 01-01-2009   #8 (permalink)
XP3
Quote  Quote: Originally Posted by Clancy52 View Post
I have that exact TV. I just tried the laptop on that tv and it worked perfect. I am in the same boat (sort of) as you are with my panasonic TV. My wife's laptop has nvidia.
link to my problem
pc to lcd via hdmi = some audio
HDMI to amp no sound Sound & Audio
problem with Radeon hd4770 no hdmi sound output Graphic cards
No sound using HDMI cabling Vista hardware & devices
no sound through hdmi?? Sound & Audio
HDMI sound problem Vista installation & setup
