| Vista Home Premium 32bit | Help please with my audio!!!! My speaker icon in the taskbar has a red cross on it. When I hover my mouse over it, it says "The audio service is not running", if I right click it I get 3 options 1. Playback devices 2. Recording devices 3. Sounds So... I went to my start menu and searched services.msc and checked to see if plug and play, windows audio endpoint builder, and multimedia class scheduler were all set to startup type automatic & all started. they were. so then i go to Windows Audio, right click to properties, and it is stopped. So i click to start it and it says "Windows could not start the Windows Audio service on Local Computer. Error 1079: The account specified for this service is different from the account specified for other services running in the same process." I tried to restore my computer but my restore point is past the point when this issue originated. Also, Conexant Driver is installed and working properly. If I right click on the volume icon with a little red X through it... I can click on Open Volume Mixer, and It says "No Audio Device Installed" Yet, my audio devices are installed. Please help!!!!! |
| Vista Ultimatex64 Windows 7 build 7100 | Re: Help please with my audio!!!! Hello tylerhess, Welcome to the forum. Have you installed any new audio drivers? Can you open Device Manager and do the same for your Audio drivers? so then i go to Windows Audio, right click to properties, and it is stopped. So i click to start it and it says "Windows could not start the Windows Audio service on Local Computer. Error 1079: The account specified for this service is different from the account specified for other services running in the same process." Pooch |
| Vista Home Premium 32bit | Re: Help please with my audio!!!! no i have not installed any new audio drivers... i am using Conexant High Definition Audio and it says it is running and working. When i click on playback devices it says.... "This computer cannot play audio because the Windows Audio Service is not enabled. Would you like to enable the Windows Audio Service?" So, I click yes. And a sound window comes up with three different tabs... playback, recording, sounds. Windows audio is when i type services.msc into my search. so i open up my services.. and scroll down to windows audio and check the properties and it says it has stopped. So i try to start it and that error comes up. |
| Vista Ultimate x64 | Re: Help please with my audio!!!! Is the audio service set to automatic when you try and start it? Also make sure the "Windows Audio Endpoint Builder" is set to automatic and running. |
| Vista Home Premium 32bit | Re: Help please with my audio!!!! yes they are both set to automatic. |
| | #6 (permalink) |
| Vista Home Premium 32bit | Re: Help please with my audio!!!! and Windows Audio Endpoint Builder is also running. |
| | #7 (permalink) |
| vista home basic 32 bit | Re: Help please with my audio!!!! hey ive just had the exact same problam, as have many others, luckily in my stressyness i did a forced shutdown so that wen i turened my laptop bak on i got the option to do a system check, choose that you want to do the check, after the check my computer restarted and i had sound agen... i am however thinking of spending my next loan installment on a mac |
| | #8 (permalink) |
| Vista Home Premium x64 | Re: Help please with my audio!!!! hey ive just had the exact same problam, as have many others, luckily in my stressyness i did a forced shutdown so that wen i turened my laptop bak on i got the option to do a system check, choose that you want to do the check, after the check my computer restarted and i had sound agen... i am however thinking of spending my next loan installment on a mac |
| | #9 (permalink) |
| Vista Home Premium x64 | Re: Help please with my audio!!!! What device is listed in the name for the audio device? We need to know more about your system in order to find out what the problem is. Do you use Realtek, a motherboard audio device, or a separate audio card? All I know ia that you are running Vista 32 bit. |
| | #10 (permalink) |
| Vista Home Premium x64 | Re: Help please with my audio!!!! Do You Have Problems with Error: 1079? Problem: Error 1079 is caused by missing system files or broken system registry structures. This is a critical sign of an unstable system that is typically caused by improper maintenance of the computer. How to Repair Error Code 1079 RegCure is a Microsoft Windows tool designed to repair code 1079 problems & errors. Download Error 1079 Repair Tool Windows 98/SE/ME/XP/Vista Compatible Quick Instructions:
More Regcure Features:
![]() Posted: February 7, 2009, 11:22am Under: Support Comments exalex Says: February 7, 2009, 8:34pm nice, it works! thx tony! Dave Says: February 7, 2009, 9:21pm thanks bro!!! finally this stupid error 1079 stopped showing /dc Says: February 9, 2009, 9:47am wasnt sure why I was getting this errer but its fixed now. thanks m@rvin Says: February 9, 2009, 4:19pm ahhh, so it was the damn registry!!! damn it!! HULK90 Says: February 10, 2009, 10:04pm wowww!!! it works yes!! THX!! eDwinn Says: February 10, 2009, 10:39pm Definatly worth getting, I can honestly say it made the biggest difference. AlphaSX Says: February 10, 2009, 11:16pm yes, haha it works... Thanks. Leave A ReplyName * Email * (will not show on comment) You may use <a href="" title=""> <abbr title=""> <acronym title=""> <b> <blockquote cite=""> <code> <em> <i> <strike> <strong> in your comment.
Windows Errors OCX Errors Last edited by Techymike; 02-12-2009 at 02:53 AM.. Reason: links |
| How do I get audio file format in audio filter driver? | Vista music pictures video | |||
| Audio drivers for Intel Sigmatel onboard audio | Vista hardware & devices | |||
| If you have a HP Laptop and No Audio Drivers/Audio Problems | Vista hardware & devices | |||
| Realtek AC'97 audio driver provided by Microsoft. Audio error MCE | Vista hardware & devices | |||
| Vista Beta 2 - Audio / Sound Drivers - Universal Audio Architectur | Vista hardware & devices | |||
