| Vista X64bit Ultimate | Problems with .MP3 Good Evening People, Well I started a small downloading spree when i got the machine built up and running, and this has me bamboozled . I Use Windows Vista X64 Ultimate edition. After downloading many different albums and such I ran into a problem. Some of them play but most of them don't. I use Windows Media Player for the audio and whenever trying to open up and music through there (or any music player rather) I run into problems.1: It will have an error pop up first saying that "the file that you are trying to play has an extension (.mp3) that does not match the file format. then it asks if you wish to continue. 2: After clicking Yes, It just says that windows cannot support the file error screen. I went to the topic at Vista Codec Pack - 32bit & 64bit Media Player Codecs downloaded the 2 different codecs, but still no music. Any ideas my Gurus? |
| Vista X64bit Ultimate | Re: Problems with .MP3 Do I have everyone stumped on this one? |
| Windows 7 RTM 64-bit | Re: Problems with .MP3 try VLC media player. VLC media player - Overview |
| Vista X64bit Ultimate | Re: Problems with .MP3 thanks dude, used the media player, still same problem. Anyone else out there? |
| Vista Home Premium x64 | Re: Problems with .MP3 maybe a file association error or a corrupt installation, what is up with using WMP? if you go to default programs>file associations in control panel and set .mp3 to play by xyz media player, it should play in that player. |
| | #6 (permalink) |
| Vista X64bit Ultimate | Re: Problems with .MP3 Thanks Mr. Needs, when I get home ill see what is wrong with it. It is using WMP, but I have found that no matter what music player I use they all seem to have the same problem. The one that was listed above that I downloaded wouldnt even do anything with the files it would just skip. Its wierd that it happens with some files that I download and not others. |
| | #7 (permalink) |
| Vista Home Premium x64 | Re: Problems with .MP3 Thanks Mr. Needs, when I get home ill see what is wrong with it. It is using WMP, but I have found that no matter what music player I use they all seem to have the same problem. The one that was listed above that I downloaded wouldnt even do anything with the files it would just skip. Its wierd that it happens with some files that I download and not others. |
| | #8 (permalink) |
| Vista X64bit Ultimate | Re: Problems with .MP3 Thanks again mr.needs It looks like they must all be corrupt .mp3 files. I dont know why i got so many that were bogus, they were all high ranking torrent files. Thanks anyways for the help bro. |
| Big vista problems need help icon/background/graphics/personalise problems | Vista performance & maintenance | |||
| laptop start up problems and problems in general | General Discussion | |||
| Problems starting command prompt on cygwin on vista ultimate, problems not had on Win2k3SP2 | Vista General | |||
| 2 different vista problems. Memory dump crash and startup repair cannot fix problems | Vista General | |||
| Downgrading from 64bit Vista to 32bit, Media Center problems, web page printing problems | Vista installation & setup | |||
