Vista - really need help!!!
Old 01-17-2009   #1 (permalink)
vista home premuim 32bit
really need help!!!
ive been trying at this for ages.im trying to install sound drivers
which is SoundMax Integrated Digital Audio
but evreytime i try to install it
it says this operating system is not supported by this software
i got a windows 32bit home premium service pack 1
any ideas
and also windows tells me
This problem was caused by SoundMax Integrated Digital Audio (LHSUS_SIS) J5420aak, which was created by Analog Devices Incorporated.
Solution
Download and install the driver for SoundMax Integrated Digital Audio (LHSUS_SIS) J5420aak from the manufacturer's website:
Follow the directions on the manufacturer's website to install the driver for SoundMax Integrated Digital Audio (LHSUS_SIS) J5420aak.
but i cant find it
