Vista - My sound keeps going to the top
Old 01-24-2009   #1 (permalink)
Vista home premium, 32 bit
Hi, i have windows vista home premium 32 bit. my computer volume, i am using the laptop speakers, keeps going to 100%. when i click on the volume icon in the bottom right, and i drag it down, it just goes straight down to the top. i ended up going to control panel and volume settings and then clicked balance, and had to individually change the right, left, sub, tweeter, and center indiviudally. anyone know what may be causing my problem? i also restarted my computer. no avail
distorted sound in vista/createiv x-fi titanium sound card Sound & Audio
Solved No sound when playing music or video, but internet sound works fine Sound & Audio
Setting per Application Sound Output, or Per Sound Type Outputs... Vista General
My Creative Sound Blaster X-FI Sound Card Works Now with Creative's RC1 Device Driver's! I Have Sound! Vista General
Vista x64 RC2 - Sound Card/Amplifier - DTS Test Sound (Audigy 2 ZS SPDIF) Vista General
