Vista - No more audio!
Old 02-03-2009   #1 (permalink)
Vista (Home, 32 bit I think?)
No more audio!
I recently messed with services.msc, disabling or setting to manual a number of services that seemed to me to be ones that I did not need to start when my computer did.
However, I guess I set to manual the Windows Audio service, which disabled my audio. It will not start. I set that service, and all of them actually, to Automatic, but it still will not start. I have no audio except for the system beep when I do something I'm not allowed to.
The only reason I haven't entirely wiped Vista from my drive (I dual-boot with Ubuntu) is for a program (TrakAxPc) which I cannot get to run on Ubuntu. However, with my audio down on Vista, it's obviously pointless to try and use an audio-mixing program.
Does anyone know how I can get my audio service back up and running?
Old 02-03-2009   #2 (permalink)
Vista Ultimate SP2 x64 Windows 7 Ultimate x64 TECHNET
Re: No more audio!
Do a system restore.
Old 02-03-2009   #3 (permalink)
Vista Home Premium x64
Re: No more audio!
Hello fellow CA person!
Old 02-04-2009   #4 (permalink)
Re: No more audio!
Quote  Quote: Originally Posted by Airbot View Post
...I have had system restore turned off. Therefore, I have no restore points, and if I was to turn the service on now, I could only restore back to this point. Thanks anyway though.
Old 02-04-2009   #5 (permalink)
Re: No more audio!
There is a list in this tutorial by Black Viper that will tell you what default the services are supposed to be set at, perhaps you've missed one related to the audio services that is still disabled.
Services
Old 02-06-2009   #6 (permalink)
Re: No more audio!
...i fixed my problem. i just installed windows 7 beta over it.
Old 02-06-2009   #7 (permalink)
Re: No more audio!
Well, I suppose that's a fix, lol. Hope you have the Vista installation disk in case you ever want to install it again. If you have win7 questions, come on over to the sister site.
Windows 7 Forums
Old 02-07-2009   #8 (permalink)
Re: No more audio!
nope, if i'd had the vista cd, i'd have just reinstalled that. but the windows 7 seems fine.
all i have to do is get my grub bootloader running again so i can get back into ubuntu
Old 02-14-2009   #9 (permalink)
32
Re: No more audio!
I think I know exactly what your problem is.
-Control Panel
-Hardware and Sound
-Sound
-Then click on the speakers or Audio output that you want to use
-And then in the bottom right hand corner it will say 'Set as Default'
-A small tick should then appear on the logo of the select
Play something through it after you have performed this operation.
It should work - sometimes you have to leave it for a few seconds and then it will work.
Hope this has helped
Playback Records
Old 02-14-2009   #10 (permalink)
Re: No more audio!
maybe that would have worked, but i've already installed the windows 7 beta over vista, and that works fine.
How do I get audio file format in audio filter driver? Vista music pictures video
Audio drivers for Intel Sigmatel onboard audio Vista hardware & devices
If you have a HP Laptop and No Audio Drivers/Audio Problems Vista hardware & devices
Realtek AC'97 audio driver provided by Microsoft. Audio error MCE Vista hardware & devices
Vista Beta 2 - Audio / Sound Drivers - Universal Audio Architectur Vista hardware & devices
